[postgis-users] Help: Performance of spatial query
chodgson at refractions.net chodgson at refractions.net
Mon Mar 15 09:59:11 PST 2004
I expect that using the geos function to buffer your point is slowing things
down because it has to convert into a geos object and back toa postgis object.
It would probably be better to just use the distance function, and then in
order to index it, build a bounding box which is effectively your buffered
point by using the minx() and miny() functions and string concatenation ie.
build the wkt of a box object by concatenating some strings with the minx() and
miny() function. Your where clause should look something like:
WHERE NOD2.shape && (concatenated string using minx/y( NOD1.shape) )
AND distance( NOD1.shape, NOD2.shape ) <= 0.2
I don't know the exact syntax for the string stuff otherwise I'd give it to
you...
HTH.
Chris
Quoting Jeremy Palmer <jpalmer at paradise.net.nz>:
> Hi,
> I have been trying to complete a query that tries to locate duplicate points
> i.e. points that have been accidentally created twice or more – These points
> may not exactly be in the same geometric position. My basic methodology is
> to complete a 0.2m proximity check for each geometry point in the database.
> The datum of the geometries is in NZGD2000 (basically the same parameters as
> WGS84).
> To do this I was using the buffer function with the overlaps operator to
> find points within 0.000002 of a degree (~ 0.2m) of each other. I was also
> trying to stop the point reporting on itself by checking that NOD1.id <
> NOD2.id. However as explain query shows below my method produces a Cartesian
> product between the 2 aliases of the node table.
> Can anyone help me with constructing a more efficient query? I have provided
> the query explain and table details if that helps.
> SELECT NOD1.id as nod_id1,
>        NOD2.id as nod_id2,
>        NOD1.shape as shape1,
>        NOD2.shape as shape2
> FROM node NOD1,
>           node NOD2
> WHERE NOD2.shape && buffer(NOD1.shape, 0.000002)
> AND   NOD1.id < NOD2.id;
> Explain Query was
>   Nested Loop  (cost=590312.88..5062636139085.67 rows=3509048593179
> width=288)
>    Join Filter: (("inner".shape && buffer("outer".shape, 2e-06::double
> precision)) AND ("outer".id < "inner".id))
>    ->  Seq Scan on crs_node nod1  (cost=0.00..379897.88 rows=10260188
> width=144)
>    ->  Materialize  (cost=590312.88..903329.76 rows=10260188 width=144)
>          ->  Seq Scan on crs_node nod2  (cost=0.00..379897.88 rows=10260188
> width=144)
> Table "public. node"
>      Column      |         Type         | Modifiers
>  id              | integer              | not null
>  cos_id_official | integer              | not null
>  type            | character varying(4) | not null
>  status          | character varying(4) | not null
>  order_group_off | integer              | not null
>  sit_id          | integer              |
>  alt_id          | integer              |
>  wrk_id_created  | integer              |
>  se_row_id       | integer              |
>  audit_id        | integer              | not null
>  shape           | geometry             |
> Indexes:
>     "pkey_node" primary key, btree (id)
>     "nod_aud_id" unique, btree (audit_id)
>     "fk_nod_alt" btree (alt_id)
>     "fk_nod_cos" btree (cos_id_official)
>     "fk_nod_sit" btree (sit_id)
>     "fk_nod_wrk" btree (wrk_id_created)
>     "nod_shape_index" gist (shape)
> Check constraints:
>     "$1" CHECK (srid(shape) = 104108)
>     "$2" CHECK (geometrytype(shape) = 'POINT'::text OR shape IS NULL)
> Thank you very much
> Jeremy Palmer
> postgis-users mailing list
