[postgis-users] Intersection doesn't work on some data
David Mitchell david.mitchell at telogis.com
Tue Mar 23 21:32:30 PST 2004
I have got two MULTIPOLYGON features, each containing a single POLYGON.
(attached). When I ask postgis to find the intersection of these, it
gives the wrong result. It should give:
MULTILINESTRING ((-121.331929 41.18388, -121.34693 41.18388),
(-121.34693 41.18388, -121.36293 41.18388), (-121.36293 41.18388,
-121.36544 41.18388), (-121.36544 41.18388, -121.37179 41.18388),
(-121.37179 41.18388, -121.37608 41.18401), (-121.37608
41.184019, -121.44593 41.18384))
But in fact gives:
MULTILINESTRING((-121.33193 41.18388,-121.34693 41.18388),(-121.34693
41.18388,-121.36293 41.18388),(-121.36293 41.18388,-121.36545
41.18388),(-121.36545 41.18388,-121.37179 41.18388),(-121.37179
41.18388,-121.37608 41.18402),(-121.37608 41.18402,1.7e-308
Note the final line string has very tiny numbers for its second
coordinate. I have written a program to run these geometries directly
through geos and the output is correct, so it must be a postgis problem.
Any help would be appreciated.
David Mitchell
Software Engineer
This message (including any attachments) contains CONFIDENTIAL
INFORMATION intended for a specific individual and purpose, and
is protected by law.  If you are not the intended recipient,
you should delete this message and are hereby notified that any
disclosure, copying, or distribution of this message, or the
taking of any action based on it, is strictly prohibited.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040324/e4b8397b/attachment.ksh>
