[postgis-users] Bounding Box Query
Tyler Mitchell TMitchell at lignum.com
Mon Mar 29 10:04:06 PST 2004
> Yes, I do to both questions.
Good, that makes it easier.
> normally, In PostGIS you get the x and y of each point shape using the
> x(geometry) and y(geometry) functions.  But In our database, the
geometry is
> in the field called the_geom, so you would get the x and y for each
> using x(the_geom) and y(the_geom).
That's good too.  You shouldn't have to use x() or y() functions with your
problem at all.
> So the query below works except it is very sloooooooow.
Sorry, I had thought you were reposting your original query, now I see
that you are just dealing with the performance issue.
> SELECT str_num || ' ' || name as full_address,
> > > >    distance(the_geom,'POINT(2227284.1963667543
> > > > 1435389.6730164126)'::geometry) as dist
> > > >    FROM address
> > > > ORDER BY dist limit 1
I understand what you are doing here, but why don't you reduce it to a
"normal" query that uses the_geom from the points and compares it to
the_geom from the lines?  RAther than explicitly saying a coordinate in
the select statement.  I.e.
       distance(a.the_geom,p.the_geom) as dist
FROM address a,
       mypoint p
WHERE ......<add where clause that selects the particular point you are
interested in>...
Now on to performance..
First off, do you have GIST indexes built for the point and lines tables?
If not, build them  (ask if you need help) and then try it again.  How
many records are dealing with in both tables?
Distance() will compare the point with EVERY road line, hence the
inefficiency.  If you have spatial indexes (GIST) built that may improve
performance for you substantially.
What you want to do is help reduce the number features that distance has
to compare.  In order to do this you want to use another to method to
first find the features that are generally close to one another.  The
"&&"/bounding box operator can help with this.  What this operator does is
it creates a rectangle (aka bounding box) around the extent of the
features and compares those to each other.  If they overlap, then you can
use the distance function to check more accurately.
You can do this by adding to your WHERE clause:
AND a.the_geom && p.the_geom
In your case, since you are using a point feature - it won't have much of
an extent since it's a discreet location.  Therefore you might not overlap
features that could be very nearby.  Also, if you have a line segment that
is long and very narrow, it will have a very narrow "bounding box" that
might not overlap any points.
So the trick is that we want to expand the bounding box so that it
overlaps more features, but not ALL of them!  Or else you're back to your
performance problem again.  You can use the EXPAND() function to do this -
but you need to decide first on the kind of distance tolerance you want it
to check around the features.
Replace the above example with:
AND a.the_geom && expand(p.the_geom,1000)
It will search within a distance of 1000 units to find overlap bounding
boxes from the lines.  Boy, it just hit me that I'm not sure if you are
comparing points with points or points with lines.  Hopefully lines :)
You could expand your lines too using the same method.
So a final solution might look something like:
FROM address a,
       mypoint p
WHERE p.point_id = 1
Does that help?
