[postgis-users] Re: Help: Performance of spatial query
Jeremy Palmer jpalmer at paradise.net.nz
Mon Mar 29 11:58:24 PST 2004
On the machine I sent the log in from I have 384mb of RAM. But I have tried
the same query on a P4 3GHz CPU with 2gb of RAM and the same problem occurs.
Also I did try running the query without the distance function and the same
problem occurs.
i.e
SELECT  NOD1.id as nod_id1,
        NOD2.id as nod_id2
FROM    node NOD1,
        node NOD2
WHERE   NOD1.shape && expand(BOX3D(NOD2.shape),0.000002)
AND     NOD1.id < NOD2.id
Thanks Jeremy
>> It maybe worth noting that I watched the postmaster process with TOP
>> until the crash. What I noticed was that the memory usage gradually
>> increased until it reached 95%, at which time postmaster then crashed.
>This means it almost certainly running out of memory.
>How much memory do you have in your machine?
>what happens if you remove the "  AND     distance(NOD1.shape, NOD2.shape)
>0.000002" from your query?
>dave
