[postgis-users] Converting a shapefile to postGIS
David Mitchell david.mitchell at telogis.com
Wed Mar 31 17:34:39 PST 2004
> The following is the command that I am using:
>  shpPg –db=gis –schema=transportation –table=Streets –dbf=<Street shapefile> -initial
> I just keep getting this error:
> Street: no such directory or file exists
The key is in the error message. Note how it says the file 'Street'
doesn't exist (not Streets). I'm betting that the command you are typing
is precisely that that you posted, right? Having -dbf=<Street shapefile>
is incorrect, and <Street shapefile> should be replaced with the name of
your dbf file. "<Street" is being interpreted as a command to pipe stdin
from the file 'Street", which is what causes the error.
David Mitchell
Software Engineer
This message (including any attachments) contains CONFIDENTIAL
INFORMATION intended for a specific individual and purpose, and
is protected by law.  If you are not the intended recipient,
you should delete this message and are hereby notified that any
disclosure, copying, or distribution of this message, or the
taking of any action based on it, is strictly prohibited.
