[postgis-users] setting SRID
Eric.Hillmuth at anr.state.vt.us Eric.Hillmuth at anr.state.vt.us
Mon May 3 11:28:20 PDT 2004
Yes, that does it.
Thank you very much!
On 30 Apr 2004 at 9:49, David Blasby wrote:
> Eric.Hillmuth at anr.state.vt.us wrote:
> > Hi all;
> > I'm using shp2pgsql and I've run into an issue that highlights my postgresql
> > weakness. If I don't specify a SRID with Shp2pgsql I end up with this CHECK
> > constraint on my new tables:
> > $1 CHECK (srid(the_geom) = -1)
> > Now that I know the SRID I want for my table I used:
> > UPDATE trails
> > SET the_geom = setsrid(the_geom,32145);
> > Which produces the error:
> > new row for relation"trails" violates check constraint "$1"
> > Seems like I need to drop this constraint before I can set my SRID? If so how do
I do
> > that?
> > I'm running Postgresql 7.4.1, PostGIS 0.8, Geos 1.0 and Pro 4.4.7 on SuSE 8.2
> > Linux.
> ALTER TABLE <table> DROP CONSTRAINT "$1";
> postgis-users mailing list
Eric Hillmuth
GIS Systems Developer
Vermont Agency of Natural Resources
eric.hillmuth at anr.state.vt.us
802-241-3616
