[postgis-users] insert polygon in multipolygon field
David Blasby dblasby at refractions.net
Tue May 4 10:43:15 PDT 2004
David TECHER wrote:
>>I want to insert a polygon (returned by
>>enveloppe(geomunion(the_geom))) into
>>a multipolygon column.  How to cast the polygon to a
>>multipolygon ?
If you have a very recent version of postgis, you can use the multi()
function.  It convert single-type to multi-types.  Ie.
POLYGON->MULTIPOLYGON.
  select multi('POINT(0 0)'::geometry);
    MULTIPOINT(0 0)
dave
