[postgis-users] How to import e00 files?
Darren Houston dhouston at beyondcompliance.ca
Tue May 4 21:53:27 PDT 2004
http://sourceforge.net/projects/e00pg
This tool is old, but I've used it before (over a year ago) and it worked.
HTH,
Darren H.
Frank Warmerdam (warmerdam at pobox.com) wrote:
> Wood Brent wrote:
> > Can anyone suggest a way to import e00 ArcInfo export files into PostGIS
> > without using a commercial GIS package?
> > I guess an e00 to shapefile converter would be a good first step :-)
> Brent,
> If you use the avcimport program (part of AVCE00) you can turn an E00
> vector coverage into a binary vector coverage.  This can be directly loaded
> into PostGIS with OGR.
>    http://avce00.maptools.org/
>    http://ogr.maptools.org/
> Of course this isn't super convenient, but it does work.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> postgis-users mailing list
