[postgis-users] Speed issues again
Paul Ramsey pramsey at refractions.net
Thu May 6 15:05:53 PDT 2004
If you mapserver is slow when running a query, the cause is almost
always the lack of an index on the unique column of the database. If you
declare a unique key in your DATA statement with "USING UNIQUE" then
that column should have an index. If you do not, then 'oid' should have
an index (create index thetable_idx on thetable (oid);).
Zamil Murji wrote:
> Hi list,
> I have run into speed issues once again. Please help me debug the situation.
> On my dev box:
... VARIOUS QUERIES ...
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
