[postgis-users] error in nquery mode
Zamil Murji Zamil.Murji at divestco.com
Fri May 7 13:41:19 PDT 2004
I have two mapfiles:
http://207.34.103.10/mapfiles/zamil.map
http://207.34.103.10/mapfiles/idcdev_canada_tooltip-query.map
The two layers are just swapped in position and you'll see why a little layer on.
http://207.34.103.10/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idcdev_canada_tooltip-query.map&imgext=74742.34494+3662569.68589+87814.60352+3671234.05290&mapsize=777+515&imgbox=410+277+420+287&layers=wells
This query returns what it is supposed to.
http://207.34.103.10/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idcdev_canada_tooltip-query.map&imgext=74742.34494+3662569.68589+87814.60352+3671234.05290&mapsize=777+515&imgbox=410+277+420+287&layers=wells+rasterlogs
This returns nothing - I would expect at least what I got from the first query.
http://207.34.103.10/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idcdev_canada_tooltip-query.map&imgext=74742.34494+3662569.68589+87814.60352+3671234.05290&mapsize=777+515&imgbox=410+277+420+287&layers=rasterlogs
This also returns nothing. However, if I swith the order of the two layers in my .map file (as in zamil.map)
http://207.34.103.10/cgi-bin/mapserv?mode=nquery&map=/mapfiles/zamil.map&imgext=74742.34494+3662569.68589+87814.60352+3671234.05290&mapsize=777+515&imgbox=410+277+420+287&layers=rasterlogs
Now returns something and
http://207.34.103.10/cgi-bin/mapserv?mode=nquery&map=/mapfiles/zamil.map&imgext=74742.34494+3662569.68589+87814.60352+3671234.05290&mapsize=777+515&imgbox=410+277+420+287&layers=wells
Now returns nothing.
Please shed some light on this issue.
Thanks in advance.
Zamil
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
Zornig Jürgen
Sent: Friday, May 07, 2004 12:42 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problem with importing "Polyline M" Shapes
Hello,
I imported a Polyline M shape which contains streets into PostGIS. The table was created and everything seemed to be good. But when I tried to import the table into ArcMap 8.3, ArcMap crashed. All other Layers (Polygons, Lines, Points) work fine.
Writing into a table from ArcGIS 8.3 also doesn´t work.
Is there a patch, or a newer Version of PgArc (I don´t even know, which Version I have installed). For the ODBC Connection, I use OpenLin 5.1 Driver.
Greets
Jürgen
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
