[postgis-users] Performance question (how many years will this take?)
Wood Brent pcreso at pcreso.com
Mon May 10 19:04:30 PDT 2004
--- Paul Ramsey <pramsey at refractions.net> wrote:
> Wood Brent wrote:
> > select into...
> > where intersects(uniq_event.the_geom, chat_cells3.the_geom);
> Is that really your where clause? You want this:
>    and uniq_event.the_geom && chat_cells3.the_geom
> So that the spatial index cuts down on the number of comparisons that
> have to be made with the expensive exact intersects() function.
I assume from this that _intersects_ does NOT do a pre-check with the GiST
bounding box before the actual polygon check?
Anyway, that appeared to run much faster, until it exited with out-of-memory
errors. Went well up into over 2G of swap being used.
What I have now done is add a
    "where cell_id >= $START_ID and $CELL_ID < $END_ID"
into the sql, and wrap it up in a script which starts at cell_id of 0 and
increments in batches of 100 cells per iteration until it gets to the maximum
cell_id. (note: there is a unique index on cell_id which is an integer attr)
This seems faster & is running without the postmaster process swapping out.
The output table is getting up to 40,000 records per 100 cells so far, and is
only taking a couple of minutes at most per 100 cell batch.
So I think this will work OK, it's about 30% done already, while I wrote this.
Thanks,
   Brent Wood
