[postgis-users] Building with mingw32
Romi Hardiyanto rodin at ewesewes.net
Thu May 13 04:17:42 PDT 2004
Dear David,
Apparently, didn't catch much time today. But attached is the diffs you
must applied before configure. One is for pgsql and one for postgis.The
pgsql.diff  changed vacuum.h in top_srcdir/src/include/command.  The
postgis.diff changed postgis.h, postgis_inout.c, and Makefile for
loader. I'll do regress later.
GEOS version is 1.0.0
PROJ version is 4.4.7
PostgreSQL and PostGIS from latest CVS
GEOS configure command is ./configure --prefix=/d/projects/build/geos
PROJ configure command is ./configure --prefix=/d/projects/build/proj
PostgreSQL configure command is ./configure
--prefix=/d/projects/build/pgsql --without-zlib (Yes, i didn't installed
zlib)
PostgGIS Makefile is:
# Configuration Directives
# Set USE_PROJ to 1 for Proj4 reprojection support
USE_PROJ=1
ifeq (${PROJ_DIR},)
    PROJ_DIR=/d/projects/build/proj
endif
# Set USE_GEOS to 1 for GEOS spatial predicate and operator
# support
USE_GEOS=1
ifeq (${GEOS_DIR},)
    GEOS_DIR=/d/projects/build/geos
endif
# Set USE_STATS to 1 for new GiST statistics collection support
# Note that this support requires additional columns in
# GEOMETRY_COLUMNS, so see the list archives for info or
# install a fresh database using postgis.sql
USE_STATS=1
Note: if you had error initdb'ing PGDATA, you have to copy libpq.dll
from pgsql\lib to pgsql\bin directory. Many PostgreSQL executables
depends on this library so it is best to copy them to pgsql\bin location
(Actually, you can set PATH environment variable to point pgsql\bin and
pgsql\lib).
Romi H
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040513/71f17869/attachment.ksh>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040513/71f17869/attachment-0001.ksh>
