[postgis-users] Building with mingw32, configure for PostgreSQL
Romi Hardiyanto rodin at ewesewes.net
Thu May 13 04:21:41 PDT 2004
Ups sorry the PostgreSQL configure script is
LDFLAGS=-lstdc++ ./configure --prefix=/d/projects/build/pgsql
--without-zlib
Romi H
Romi Hardiyanto wrote:
> Dear David,
> Apparently, didn't catch much time today. But attached is the diffs you
> must applied before configure. One is for pgsql and one for postgis.The
> pgsql.diff  changed vacuum.h in top_srcdir/src/include/command.  The
> postgis.diff changed postgis.h, postgis_inout.c, and Makefile for
> loader. I'll do regress later.
> GEOS version is 1.0.0
> PROJ version is 4.4.7
> PostgreSQL and PostGIS from latest CVS
> GEOS configure command is ./configure --prefix=/d/projects/build/geos
> PROJ configure command is ./configure --prefix=/d/projects/build/proj
> PostgreSQL configure command is ./configure
> --prefix=/d/projects/build/pgsql --without-zlib (Yes, i didn't installed
> zlib)
> PostgGIS Makefile is:
> # Configuration Directives
> # Set USE_PROJ to 1 for Proj4 reprojection support
> USE_PROJ=1
> ifeq (${PROJ_DIR},)
>    PROJ_DIR=/d/projects/build/proj
> endif
> # Set USE_GEOS to 1 for GEOS spatial predicate and operator
> # support
> USE_GEOS=1
> ifeq (${GEOS_DIR},)
>    GEOS_DIR=/d/projects/build/geos
> endif
> # Set USE_STATS to 1 for new GiST statistics collection support
> # Note that this support requires additional columns in
> # GEOMETRY_COLUMNS, so see the list archives for info or
> # install a fresh database using postgis.sql
> USE_STATS=1
> Note: if you had error initdb'ing PGDATA, you have to copy libpq.dll
> from pgsql\lib to pgsql\bin directory. Many PostgreSQL executables
> depends on this library so it is best to copy them to pgsql\bin location
> (Actually, you can set PATH environment variable to point pgsql\bin and
> pgsql\lib).
> Romi H
> --- /d/fromoutsideworld/pgsql/src/include/commands/vacuum.h	Mon Feb 16 04:01:39 2004
> +++ /d/projects/compile/pgsql/src/include/commands/vacuum.h	Thu May 13 03:34:14 2004
> @@ -122,7 +122,7 @@
>  } VacRUsage;
>  /* Default statistics target (GUC parameter) */
> -extern int	default_statistics_target;
> +extern DLLIMPORT int	default_statistics_target;
>  /* in commands/vacuum.c */
> diff -Naur /d/fromoutsideworld/postgis/loader/Makefile /d/projects/compile/pgsql/contrib/postgis/loader/Makefile
> --- /d/fromoutsideworld/postgis/loader/Makefile	Thu Feb  5 16:07:32 2004
> +++ /d/projects/compile/pgsql/contrib/postgis/loader/Makefile	Thu May 13 17:46:35 2004
> @@ -50,9 +50,9 @@
>  	$(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
>  install: all
> -	$(INSTALL_PROGRAM) pgsql2shp$(EXE) $(DESTDIR)$(bindir)/pgsql2shp$(EXE)
> -	$(INSTALL_PROGRAM) shp2pgsql$(EXE) $(DESTDIR)$(bindir)/shp2pgsql$(EXE)
> +	$(INSTALL_PROGRAM) pgsql2shp$(X) $(DESTDIR)$(bindir)/pgsql2shp$(X)
> +	$(INSTALL_PROGRAM) shp2pgsql$(X) $(DESTDIR)$(bindir)/shp2pgsql$(X)
>  clean:
> -	@rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE) pgsql2shp$(EXE)
> +	@rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(X) pgsql2shp$(X)
> diff -Naur /d/fromoutsideworld/postgis/postgis.h /d/projects/compile/pgsql/contrib/postgis/postgis.h
> --- /d/fromoutsideworld/postgis/postgis.h	Sun Mar 28 19:42:25 2004
> +++ /d/projects/compile/pgsql/contrib/postgis/postgis.h	Thu May 13 17:50:37 2004
> @@ -94,7 +94,7 @@
>   * it defines BYTE_ORDER and LITTLE_ENDIAN
> -#ifdef __CYGWIN__
> +#if defined(__CYGWIN__) || defined(__MINGW32__)
>  #include <sys/param.h>       // FOR ENDIAN DEFINES
>  #endif
> @@ -669,8 +669,10 @@
>  // from contrib/cube/cube.c
> +#if !defined(__MINGW32__)
>  #define max(a,b)		((a) >	(b) ? (a) : (b))
>  #define min(a,b)		((a) <= (b) ? (a) : (b))
> +#endif
>  #define abs(a)			((a) <	(0) ? (-a) : (a))
> diff -Naur /d/fromoutsideworld/postgis/postgis_inout.c /d/projects/compile/pgsql/contrib/postgis/postgis_inout.c
> --- /d/fromoutsideworld/postgis/postgis_inout.c	Thu Apr 29 08:49:37 2004
> +++ /d/projects/compile/pgsql/contrib/postgis/postgis_inout.c	Thu May 13 17:50:10 2004
> @@ -1617,8 +1617,14 @@
>  				char *last_paren;
>  				char *current_paren;
> +        //from mappostgis.c
> +		#if defined(__MINGW32__)
> +				first_paren= strchr (str,'(');
> +				last_paren = strrchr(str,')');
> +		#else
>  				first_paren= index (str,'(');
>  				last_paren = rindex(str,')');
> +		#endif
>  				if  ( (first_paren == NULL) || (last_paren == NULL) || (first_paren >last_paren) )
> postgis-users mailing list
