[postgis-users] Migration: From Oracle to PostgreSQL
Zamil Murji Zamil.Murji at divestco.com
Thu May 13 09:48:39 PDT 2004
Hello Alex,
We have been using an open source utility called Ora2Pg. It is very well written and easy to use. I could not find a way to migrate the spatial column from Oracle to Postgres directly. For our company this was not a problem, since we stored the lat and long in seperate columns anyways. I pulled everything once, and then ran an update script to create my geometry column and populate it. We had to slightly modify the Ora2Pg code so that a user without sys privileges could export from the Oracle table, but that was the only change we made to the core package.
I hope this helps,
Zamil
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Alex
Martins Daher
Sent: Thursday, May 13, 2004 10:34 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Migration: From Oracle to PostgreSQL
Hi everyone!
Is there any tool so that I can migrate (spatial) data from an Oracle
database to PostgreSQL. Does pgadmin have any?
So, what is the easiest and less painful way to do this migration?
Regards,
Alex
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
