[postgis-users] RE:postgis and mapserver problem
Jeremy Palmer jpalmer at paradise.net.nz
Mon May 17 13:44:20 PDT 2004
Hi Jan,
Thanks for the reply. I tried setting STATUS DEFAULT and using
"&layer='node'" however I still get no image back? My apache log says:
"Premature end of script headers: mapserv" when I make the request.
Thanks
Jan Hartmann wrote:
Hi Jeremy,
This seems to be the eternal STATUS DEFAULT problem. STATUS ON means that
the calling URL has to indicate explicitly that the layer should be
displayed (http://...?map=...&layer=...). Only layers with STATUS DEFAULT
are always shown. It is confusing, and you are not the first one to have run
into this.
Jan
Jeremy Palmer wrote:
From: Jeremy Palmer [mailto:jpalmer at paradise.net.nz]
Sent: Monday, 17 May 2004 11:00 p.m.
To: 'postgis-users at postgis.refractions.net'
Subject: postgis and mapserver problem
Hi I'm trying to display Postgis data through Mapserver but all I get back
is a blank image. I have got mapserver demo/samples working with shape
files.
The map file I'm using is:
NAME TEST
SIZE 400 300
# lat long extents
EXTENT 5 -48 24 -35
UNITS METERS
IMAGECOLOR 255 255 255
IMAGETYPE PNG
#NZGD2000 datum
PROJECTION
    "init=esri:104108"
END
LAYER
  CONNECTIONTYPE postgis
  NAME "node"
  # Trusted connection to db 'dblh' on host 'lh-deimos'
  CONNECTION "user=postgres dbname=dblh host=lh-deimos"
  # Select column shape from table node
  DATA "shape FROM node"
  STATUS ON
  TYPE POINT
    CLASS
       COLOR 0 0 0
    END
 END
END # Map File
The http request I'm using is:
http://lh-deimos/cgi-bin/mapserv?map=/var/www/htdocs/map/test.map&mode=map
I'm using:
Postgresql 7.42
Postgis 0.81
Geos 1.0
Proj 4.47
mapserver 4.02
Thanks
