[postgis-users] Building with mingw32, configure for PostgreSQL
Craig Miller craig.miller at spatialminds.com
Mon May 17 14:22:04 PDT 2004
I was able to get everything to compile except PostGIS with GEOS support.
PostGIS w/o GEOS support works, and the GEOS compile works good too.  I saw
in your notes that you said you had to copy the GEOS header files to
/include.  This directory does not exist in a default msys installation.
Did you add it?
Thanks,
--Craig
-----Original Message-----
From: David TECHER [mailto:davidtecher at yahoo.fr]
Sent: Monday, May 17, 2004 5:36 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Building with mingw32, configure for
PostgreSQL
 Hi Craig
can you give me the file or the URL where you have
seen this?
Did you succeed in compiling?
> I remember that you posted a message about having
> trouble creating indexes
> on large datasets with the mingw version of postgis
> you compiled.  I read a
> note in the postgresql compile notes that said to be
> sure to run postgres
> from a normal DOS cmd prompt and not an rxvt shell
> due to some sort of
> memory limitation.  Perhaps this is what is causing
> the trouble with large
> datasets?
> --Craig
> Sent: Thursday, May 13, 2004 8:30 AM
> Subject: Re: [postgis-users] Building with mingw32,
> configure for
> PostgreSQL
>   Dear Romi
> thanks thanks very much I succeed I succeed after
> two
> weeks of work
> I'm happy...You know I'm happy :)
> Yahoo! Mail : votre e-mail personnel et gratuit qui
> vous suit partout !
> Créez votre Yahoo! Mail sur
> http://fr.benefits.yahoo.com/
> Dialoguez en direct avec vos amis grâce à Yahoo!
> Messenger !Téléchargez
> Yahoo! Messenger sur http://fr.messenger.yahoo.com
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
Dialoguez en direct avec vos amis grâce à Yahoo! Messenger !Téléchargez
