[postgis-users] simplify() on lat/lon data
David Blasby dblasby at refractions.net
Fri May 21 09:46:13 PDT 2004
strk wrote:
> Are you suggesting a spherical_simplify() ?
> If you want to try, replace distance_pt_seg at postgis_algo.c:86
> with a call to a chord distance function and see what happen.
Theres distance-on-ellipse calculations already available in postgis -
see postgis_proj.c.
You can call distance_ellipse() to give the distance-on-ellipse or you
can call distance_sphere_method() which is much faster but less
accurate.  For distances in the "few meters" range, I recommend the
distance_sphere_method() - see the documentation for how it works.
REMEMBER: the lat/lot number have to be in radians (i.e. *M_PI/180.0).
dave
