[postgis-users] Incorrect results from queries specifying an SRID
cp cplists at yeroc.ca
Fri May 28 13:33:17 PDT 2004
Wood Brent wrote:
>I think you'll find "normal" spatial queries do not use projection data
>on-the-fly. You'll need to reproject one dataset to the same projection as the
>other. The transform funtion will do this.
If this is the case then the queries should error when the projections
do not match.
Corey
