[postgis-users] Compilation
Shaz Shaz shaz850 at yahoo.co.uk
Sun May 30 02:23:40 PDT 2004
Thanks for the reply Paul.
The problem is that I have other things that rely on
an old version of Postgres, postgres 7.2. Because of
that I would like to integrate postgis in to my
current redhat postgres version. You also don't have
rpms for postgres 7.2 on Redhat 7.3. Is there a way of
compiling  postgis and placing it in a location on the
existing RedHat postgres 7.2 install. Could someone
please describe a way of doing this, without losing
the RedHAT postgres install?
Thanks very much for your help.
Regards
Roger
 --- Paul Ramsey <pramsey at refractions.net> wrote: > If
you want an RPM, why not use the SRPMS provided
> at
> http://postgis.refractions.net/rpms ? And no, there
> is not a document
> because it is not an 1,2,3 kind of thing. You learn
> enough about
> compilation and RPM, and then you just do it. I
> started with the
> postgresql source RPM and worked from there to
> create a unified SRPM
> including postgis.
> Rider Matey wrote:
> > Hi
> > Similar to what the other person had with his
> > compilation problem, I tried to go through the
> > instructions. The problem I had was if I download
> the
> > source from postgres then how do I put postgis
> into
> > the redhat postgres installation?. Is there a
> document
> > on how to create redhat postgresql rpms which
> include
> > postgis
> > Thanks in advance.
> > Roger
> > Shaz,
> > I run a redhat 7.3 installation, and it requires a
> > postgresql source
> > tree,
> > and a few other gizmos. Details are available:
> > http://postgis.refractions.net/docs/c59.html
> > Good luck, and if you run into problems, email, I
> may
> > have some
> > assistance.
> > r..b.
> > At 10:48 AM 5/28/2004 +0100, you wrote:
> >>Hi
> >>I am new to postgis. I want to compile postgis
> with
> >>redhat postgres 7.3. Could anyone please explain
> how
> >>this is done for redhat versions. I know you have
> > rpms
> >>but I would like to try to compile it myself. Any
> > help
> >>will be very much appreciated.
> >>Thanks
> >>Shaz
____________________________________________________________
> > Yahoo! Messenger - Communicate instantly..."Ping"
> > your friends today! Download Messenger Now
> > http://uk.messenger.yahoo.com/download/index.html
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
