[postgis-users] Desperately seeking simple solution
Robert W. Burgholzer rburgholzer at maptech-inc.com
Sun May 30 16:31:12 PDT 2004
Gerry,
I guess it would be helpful to know what exactly you want to do with the
resulting data. Are you simply taking it from one form, like a dbf file or
a flat text file (such as NCDC or NOAA data), and then copying it into
postgis, or are you looking for some other type of implementation?
I have done a bit of what I describe above, i.e., creating a point theme
with weather station data from NCDC, and importing text based data with the
actual readings into a separate table. This has gone fairly smoothly with
simple queries and so forth. The resulting tables are then quite
conveniently accessed for a variety of applications once inside
postgresql/postgis.
Feel free to email me on or off list if you would like to discuss further,
or perhaps see some of the scripts I have written to accomplish these tasks.
r.b.
At 09:10 AM 5/30/2004 -0500, you wrote:
>I've got a postgres database that incorporates point data.  One table
>holds lat/lon and other site (static) info, while another table houses all
>the time-dependent data.  We're talking surface meteorological data for
>the most part.
>I'm trying to transition a big chunk to PostGIS and was wondering if
>there's a relatively easy way to do it.  I don't want to take the site
>down for several days, so the transition will have to occur off-line, and
>then I'll do a swap.
>I'm sorta at a loss right now for ideas and don't want to trash my
>existing db in trying this.
>Thanks for all suggestions!
>gerry
>Gerry Creager -- gerry.creager at tamu.edu
>Texas Mesonet -- AATLT, Texas A&M University
>Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>Page: 979.228.0173
>Office: 903A Eller Bldg, TAMU, College Station, TX 77843
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Robert Burgholzer
Environmental Engineer
MapTech Inc.
http://www.maptech-inc.com/
