[postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
Romi Hardiyanto rodin at ewesewes.net
Sun May 30 19:36:19 PDT 2004
Well, this is a very great work. I didn't notice the index throw errors
when uploading my road data.
Many thanks.
Romi H
Mark Cave-Ayland wrote:
> Hi Emil,
> Thanks for the feedback regarding the performance of the Win32
> PGSQL/PostGIS snapshot - it's good to hear that someone else has managed
> to get it working successfully. It will be interesting to see if other
> people experience the same level of performance that you have, and how
> different it will be to tune PostgreSQL for Win32. I'll keep an eye on
> the list for other reports of BSOD when restarting while the server is
> still active, and if it is a problem then I shall mention it to the
> PostgreSQL-Win32 people.
> Many thanks,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender. You
> should not copy it or use it for any purpose nor disclose or distribute
> its contents to any other person.
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Emil Zegers
>>Sent: 28 May 2004 11:49
>>To: postgis-users at postgis.refractions.net
>>Subject: [postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
>>Hello Mark,
>>Your Win32 PostgreSQL 7.5/PostGIS snapshot is working great!
>>This morning I downloaded and installed the newest version
>>with GiST index patch.
>>Imported some shapefile data (point file with >88000 points)
>>and made indexes on it.
>>I'm viewing the data through a MapServer client.
>>Performance is great and the database is stable too on my
>>Windows 2000 system.
>>About the batch files running order: I run env.bat before
>>initdb.bat otherwise the path is not correct.
>>Thanx for the 'Ctrl-C' tip to shutdown the server.
>>If I restart the system without shutting down I get a BSOD
>>before rebooting.
>>Again, thanks for sharing this software.
>>Best regards,
>>Groeten,
>>Emil Zegers
>>De Straat Milieu-adviseurs
>>Divisie Informatisering
>>026 7513902
>>06 22965585
>>http://www.destraat.nl
>>______________________________________________________
>> This message has been checked for all known viruses
>>postgis-users mailing list postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
