[postgis-users] Converting ESRI Geodatabase
Paul Ramsey pramsey at refractions.net
Tue Nov 9 16:51:08 PST 2004
Interesting, I did not read your question closely enough to note you
are playing w/ annotation.
In general, the text I have seen in ESRI binary streams is just
null-terminated ASCII. Perhaps you could extract some of the LBOs and
post them here as an attachment and we can all open our hexeditors on
it and give our opinions. :)
On 9-Nov-04, at 2:29 PM, Steve Lehr wrote:
> Paul:
> Thanks that's the first LBO, any insight on the second Element LBO
> which
> houses the actual text?  I guess its an ESRI Elment Object within it
> containing a Text Symbol?
> Thanks
> Steven Lehr
> Assistant Professor
> Freshmen Program
> College of Engineering
> Embry-Riddle Aeronautical University (LB159)
> 600 S. Clyde Morris Blvd.
> Daytona Beach, FL 32114-3900
> 386-226-7740
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Paul
> Ramsey
> Sent: Tuesday, November 09, 2004 3:55 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Converting ESRI Geodatabase
> Apparently it is the same format as shape files use, so start w/ the
> Shape file specification and work from there. Should be pretty easy.
> P
> Steve Lehr wrote:
>> I'm trying to extract the point/annotation information from an ESRI
>> Geodatabase stored in MS Access.
>> Does someone have the format for the LBO so that I can unpack the
>> data and
>> extract the x,y,angle, and text for labels/annotation.
>> Thanks.  Beer is on me if you have the answer :-)
>> Steven Lehr
>> Assistant Professor
>> Freshmen Program
>> 386-226-7740
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
