[postgis-users] Can't compile Postgis 0.9.0 on Postgress7.4.5.1(Cygwin)
Januar V. Simarmata januar at web4yours.com
Mon Oct 4 04:29:54 PDT 2004
Hi Strk,
I am sure it is an environmental issue, not a code bug.
Anyway, I've looked at behind the "letter" and found that it is "3C". That's
different with the ascii code you mentioned before.
Other thing,
I don't understand very much about preprocessor. How to check this?
I am using:
$ gcc --version
gcc (GCC) 3.3.3 (cygwin special)
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ make --version
GNU Make 3.80
Copyright (C) 2002  Free Software Foundation, Inc.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Needs you help,
Jan
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, October 04, 2004 2:46 PM
Subject: Re: [postgis-users] Can't compile Postgis 0.9.0 on
> On Mon, Oct 04, 2004 at 10:34:34AM +0700, Januar V. Simarmata wrote:
> > I found that it is already '<' character:
> > #if GEOS_LAST_INTERFACE < 2
> > How to fix it?
> It's not a bug!
> My guess was the '<' is not really a '<' but an equivalent-looking
> char. Two things to check:
> 1) Is it really a '<' ?
> 2) Does you preprocessor accept that kind of expression ?
> --strk;
> > cheers,
> > Jan
> > From: <strk at refractions.net>
> > To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
> > Sent: Sunday, October 03, 2004 11:00 PM
> > Subject: Re: [postgis-users] Can't compile Postgis 0.9.0 on Postgress
> > 7.4.5.1(Cygwin)
> > > On Sun, Oct 03, 2004 at 09:15:14PM +0700, Januar V. Simarmata wrote:
> > > > postgis_geos_wrapper.cpp:203:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:245:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:278:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:363:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:399:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:437:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:469:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:533:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:565:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:1519:5: invalid character '\206' in #if
> > > > postgis_geos_wrapper.cpp:1535:5: invalid character '\206' in #if
> > > > make: *** [postgis_geos_wrapper.o] Error 1
> > > Is it the '<' char ??
> > > Can it be something changed it into a weird char ?
> > > Check those line and make sure the '<' is actually an ascii '<'
> > > (\074)
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
