[postgis-users] select asSVG(the_geom) || 'mytext' from mytable -- does not work
strk at refractions.net strk at refractions.net
Fri Oct 15 04:48:43 PDT 2004
On Fri, Oct 15, 2004 at 12:46:30PM +0200, Jorg Heymans wrote:
> Hi,
> Above construct does not work because asSVG seems to tag a newline at
> the end of it's output.
> Following works:
> select substring(asSVG(the_geom), 0, length(asSVG(the_geom))-1)
> Thoughts?
> Jorg Heymans
I've checked, the offending char was not a newline, but a random
char, which in your case (maybe all cases?) was a ZERO (EOS).
The bug is now fixed in the 0_9 and the HEAD branch.
--strk;
> postgis-users mailing list
