[postgis-users] Projection help (please)
Chapman, Martin MChapman at sanz.com
Tue Oct 26 16:22:05 PDT 2004
Brent,
One more note.  You need to call OGRRegisterAll(); before any of the
code in the message below.  The code below uses the OGR library, which
under the hood uses Proj4.  The on-line docs I was referring to are
located at
http://www.remotesensing.org:16080/gdal/ogr/classOGRSpatialReference.htm
l
Martin
-----Original Message-----
Sent: Tuesday, October 26, 2004 5:18 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Projection help (please)
Brent,
#include "ogrsf_frmts.h"
#include "gdal_priv.h"
char* pszWks = "the text from the .prj file goes here";
OGRSpatialReference spatialReference(pszWks); OGRErr err =
spatialReference.morphToESRI(); // needed if the using an esri .prj file
if (err != OGRERR_NONE) throw (char*) CPLGetLastErrorMsg();
char* pszProj4 = NULL; spatialReference.exportToProj4(&pszProj4);
-- there you go
-- p.s I think the pszProj4 variable should be freed with
CPLFree(pszProj4); -- not sure though, see the on-line docs for that
Martin
Sent: Tuesday, October 26, 2004 5:05 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Projection help (please)
I have been given a Mapinfo binary map with CCAMLR data around
Antarctica.
ogr2ogr turned it into a shapefile which is more useful I want to import
this into a PostGIS table, but need to sort out the projection details
to overlay it with other data in the database.
The shapefile version includes a .prj file, which I'm assuming will have
the necessary info to locate or create the appropriate entry in the
spatial_ref_sys table.
The contents of this file are below, can anyone help me translate this
into a proj4text string?
Thanks,
   Brent Wood
more CCAMLR/Subareas_new_2003.prj
PROJCS["unnamed",GEOGCS["unnamed",DATUM["North_American_Datum_1927",SPHE
ROID["C
larke
1866",6378206.4,294.9786982],TOWGS84[-8,160,176,-0,-0,-0,0]],PRIMEM["Gre
e
nwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Azimuthal_Equid
istant"
],PARAMETER["latitude_of_center",-90],PARAMETER["longitude_of_center",0]
,PARAME
TER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1.0]]
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
