Fwd: [postgis-users] error loading postgis.sql on OS X 10.3.3
Joshua Lieberman josh at oklieb.net
Mon Sep 6 10:25:36 PDT 2004
I too have not solved this problem. It appears that stdc++ is being
linked in as a dynamic library but is only available in the OS X
distribution as a static archive (.a). I have neither tracked down a
dynamic library file (.dyld.so) nor gone so far as to rebuild gcc 3.3 to
see if I can get on. Someone did build gcc3.4 and succeeded in loading
the PostGIS procedures, but conflicts between codes compiled with the
two different gcc versions appear wreaked havoc for them with other
software.
Would certainly appreciate help from someone more familiar with OS X C++
development to resolve this.
Thanks in advance,
Josh Lieberman
Benoit Ogier wrote:
> Hi,
> I'm new on postgis, and Mac OS X user... I found this message of
> january and I got same error under OS 10.3.3 with postgres 7.4.5, GCC
> 3.3, and postgis 0.8.2, when using GEOS 1.0.
> Did someone find any solution for this trouble ???
> My config line for postgress :
> LDFLAGS=-lstdc++ ./configure -bindir=/usr/local/bin
> --mandir=/usr/local/share/man/ --enable-recode --with-CXX
> --enable-odbc --enable-syslog --enable-unicode-conversion
> --enable-multibyte
> Thanks,
> BO
>     Hi I'm back. Trying to upgrade my PostGIS installation it turned
>     out to
>     be tough to get the pieces all together, as usual!
>     The error, shown below, sounds as if my Pgsql is not compiled with
>     C++
>     support, but I did indicate stdc++ on the configure options for Pgsql
>     (for GEOS support) Any ideas where I went wrong?
>     gcc -v
>     Reading specs from /usr/libexec/gcc/darwin/ppc/3.3/specs
>     Thread model: posix
>     gcc version 3.3 20030304 (Apple Computer, Inc. build 1495)
>     PostgreSQL 7.4.1
>     ./configure --with-perl --with-rendezvous --without-readline
>     LDFLAGS="-lstdc++ -L/usr/local/lib"
>     PostGIS 0.8.1
>     Makefile: USE_PROJ = 0, GEOS = 1, USE_STATS = 0
>     Here is the error loading postgis.sql:
>     # /usr/local/pgsql/bin/psql -U postgres -f
>     /usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql -d
>     aps
>     BEGIN
>     message
>     PL/PgSQL is installed.
>     (1 row)
>     psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:
>     44: NOTICE: type "histogram2d" is not yet defined
>     DETAIL: Creating a shell type definition.
>     44: ERROR: could not load library
>     "/usr/local/pgsql/lib/libpostgis.so.0.8": dyld:
>     /usr/local/pgsql/bin/postmaster Undefined symbols:
>     __ZNSs20_S_empty_rep_storageE
>     __ZNSs4_Rep11_S_max_sizeE
>     __ZNSs4_Rep11_S_terminalE
>     __ZNSt24__default_alloc_templateILb1ELi0EE12_S_force_newE
>     __ZNSt24__default_alloc_templateILb1ELi0EE12_S_free_listE
>     __ZNSt24__default_alloc_templateILb1ELi0EE22_S_node_allocator_lockE
>     __ZTIPv
>     __ZTVN10__cxxabiv117__class_type_infoE
>     __ZTVN10__cxxabiv119__pointer_type_infoE
>     __ZTVN10__cxxabiv120__si_class_type_infoE
>     __ZTVN10__cxxabiv121__vmi_class_type_infoE
>     ___cxa_pure_virtual
>     ___gxx_personality_v0
>     49: ERROR: current transaction is aborted, commands ignored until end
>     of transaction block
>     ... snip rest of errors ..
>     Alex Rice, Software Developer
>     Architectural Research Consultants, Inc.
>     <http://ARCplanning.com>
> Benoît Ogier{
> Carte Blanche Conseil
> 47, rue de Lancry
> 75010 Paris
> Tel : +33 1 42 41 21 21
> Fax : +33 1 42 41 70 40
> email : benoit.ogier at cbconseil.com
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
