[postgis-users] AsSVG()
Andreas Neumann neumann at karto.baug.ethz.ch
Thu Sep 9 23:13:04 PDT 2004
Hello,
I would also strongly encourage the inclusion of the AsSVG() patch into
the main source tree of Postgis. Being able to control the accuracy (nr
of decimal places) is also very important for me. Thanks for providing
the patch!
I personally use SVG and Postgis a lot in SVG mapping projects (see f.e.
http://www.carto.net/geog234/lab7/index.svg - be careful with loading
the contour lines (those are not well optimized for web-use))
I am currently in Japan at the SVG.Open, UBIMap and CSIS Symposium.
SVG for webmapping is very popular in Japan and just recently strongly
recommended in Japan as a standard way to display spatial data on the
web and mobile devices. Furthermore the two biggest mobile companies
(NTT, KDDI) invest a lot in SVG for mobile devices.
http://www.svgopen.org/2004/proceedings_en.html (look for goSVG and LBS
services) and www.jamaps.com
KDDI is strongly pushing SVG to also become a international standard for
Location  based services.
Finally: SVG can also be used for digitizing geographic data and feed it
into Postgis: http://www.carto.net/papers/svg/digi/ - that project is
still immature and at an early stage, but I think the idea might be
interesting.
So, please include it in the Postgis distribution - it is very important!
Andreas
btw: KDDI (second largest mobile provider in Japan) also uses Postgres
for providing LBS data. Currently they don't use Postgis, since they
only serve point-locations so far.
Andreas Neumann - Department of Cartography
Swiss Federal Institute of Technology (ETH)
ETH Hoenggerberg, CH-8093  Zurich, Switzerland
Phone: ++41-1-633 3031, Fax: ++41-1-633 1153
e-mail: neumann at karto.baug.ethz.ch
www: http://www.karto.ethz.ch/neumann/
SVG.Open: http://www.svgopen.org/
Carto.net: http://www.carto.net/
