[postgis-users] Intersects() and large datasets: error?
Hubert Fröhlich hubert.froehlich at bvv.bayern.de
Wed Sep 22 07:32:29 PDT 2004
Hi list,
I am working with PostgreSQL 7.4.1, Postgis 0.8.2 and GEOS 1.0.0 .
I have a table with some columns and a geometry column for MULTIPOLYGONs
I try to test the scenario "give me the geometry containing a point with
given coordinates (borders included)" with some SQL statement like
select col1, col2  from table1 where pgpoly &&
geometryfromtext('POINT(4427268.73 5477865.96))', 31494) and
intersects(geometryfromtext('POINT(4427268.73 5477865.96))', 31494),
pgpoly);
When the table is filled with a sub-dataset (ca. 80 000 multipolygons)
of my final data, everything works fine.
When I use my dataset (ca. 10 mill. multipolygons) , I get errors like
NOTICE:  TopologyException: side location conflict (4.42661e+06,5.47702e+06)
ERROR:  GEOS intersects() threw an error!
The box overlap alone
works properly.
What has gone wrong?
Regards,
Hubert
Dr.-Ing. Hubert Fröhlich
Bezirksfinanzdirektion München
Alexandrastr. 3, D-80538 München, GERMANY
Tel. :+49 (0)89 / 2190 - 2980
Fax  :+49 (0)89 / 2190 - 2997
hubert dot froehlich at bvv dot bayern dot de
