[postgis-users] Postgis data loading
Brent Wood pcreso at pcreso.com
Thu Apr 7 18:41:02 PDT 2005
Apologies,
The info in the new manual does cover this, but as I'm using v0.8, so am
without lwgeom & EWKT, etc,  I was using the manual for 0.8 which did not
explain this as well.
Thanks for the help (& the improved docs!)
  Brent
> > There is no mention of copy as a means of loading data in the PostGIS docs
> > (section 4.3), just sequences of insert sqls.
> > So is there some reason I'm unaware of which makes copy unsuitable, or is
> it
> > just an omission?
> All examples used GeomFromText(), I think to reduce documented "promises".
> It came handly when switching between 0.x and 1.x as canonical input
> changed between the two.
> Anyway, you can read something in 4.1.2.
> Actually you can read the whole manual and stop indulging.
> --strk;
> > Brent
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
