[postgis-users] Problems with GeomUnion
Bill Binko bill at binko.net
Fri Apr 8 08:08:59 PDT 2005
On Thu, 7 Apr 2005, Martin Davis wrote:
> > Now I need a way to fix self-intersecting shapes.
> If you do a buffer(0) on the shapes as you load them (or after you load
> them), that will convert them to valid geometry while preserving their
> outline.
I'm having some issues with that solution (and I was very excited to hear
such a simple one!).  When I run this:
update parcels set parcel_shape = buffer(parcel_shape, 0);
I get:
ERROR:  new row for relation "parcels" violates check constraint "enforce_geotype_parcelShape"
that constraint looks like:
Check constraints:
    "enforce_dims_parcelShape" CHECK (ndims(parcel_shape) = 2)
I thought I'd check which ones weren't of dimension 2, so I ran:
SELECT oid from parcels where ndims(buffer(parcel_shape, 0)) != 2)
That gives me:
NOTICE:  IllegalArgumentException: points must form a closed linestring
NOTICE:  IllegalArgumentException: geometries must not contain null elements
ERROR:  POSTGIS2GEOS conversion failed
So, obviously, I have some real issues in this data.
I thought I might get to the bottom of it with this query:
gis=# select oid from (select oid, isvalid(buffer(parcel_shape, 0)) as valid from parcels) as foo where valid = false;
But I got:
ERROR:  invalid memory alloc request size 0
That can't be good. :-(
Anyway, I'm still plugging at it, so any help is fabulous.
> > I wonder why I didn't get errors when loading the shapefiles into the
> database!
> Shapefiles are notoriously tolerant of invalid geometry topology.  For
> different reasons, so is PostGIS.  Sometimes it's nice to be able to
> load invalid geometry and then clean it up in a subsequent step.  If
> PostGIS refused to load your bad shape, you might have no way of knowing
> what the bad linework was or what the error was.
Understood: I'll just have to learn how to clean it up :)
Bill
