[postgis-users] Distances from geometries other than points
Julian Scarfe julian at avbrief.com
Fri Apr 15 00:52:16 PDT 2005
>I have a table of worldwide objects with a WGS84 latitude-longitude
>location as a POINT with SRID=4326.
> To find objects within specified earth-surface distances of a POINT seems
> straightforward using e.g.:
> distance_spheroid(
>    object.location,
>    PointFromText('POINT (0.5 52.5)', 4326),
>    'SPHEROID["WGS_1984", 3444.0, 298.257223563]'
> to calculate, for example, the distance in nautical miles.
> But I'd like to be able to find all those objects within specified
> earth-surface distances (different for each object) of other geometries,
> for example a line or rectangle.
> How can I do that, please? distance_spheroid(geometry, geometry) seems to
> support only points and distance(geometry, geometry) returns a
> "flat-earth" distance.
OK, so if no one will bite on that one, let me ask a slightly different
question.
Can I extend PostGIS to incorporate functions that allow me to find, e.g.
shortest distances on a sphere between a point and a line (great circle),
and if so, where should I look to find out how to do that?  [I'm not asking
for algorithms, which I have, I'm wondering how to add functions that accept
geometries as parameters, and for examples.]
Thanks
Julian Scarfe
