[postgis-users] WARNING: cache reference leak: cache pg_statistic (31), tuple 0 has count 1
Ron Mayer rm_postgis at cheapcomplexdevices.com
Mon Apr 18 00:32:05 PDT 2005
I have some queries that are giving me a
   " WARNING:  cache reference leak: cache pg_statistic (31), tuple 0 has count 1 "
warning message in my log file when I run them.
I'm using a couple days ago's (either thursday or friday's) CVS version.
According to the wonderfully helpful people on postgresql's IRC,
  "the catcache issues that warning at the end of a transaction if
   there are outstanding references to cached items ...
   since it's pg_statistic that is being complained about, the most
   likely culprit is a selectivity estimator function.. since those
   use rows from pg_statistic to base estimates on"
The problem goes away if I "ANALYZE" all my tables involved in the query.
I can re-create the problem by doing TRUNCATE TABLE on the table
wiith the MULTIPOLYGON and re-inserting the data, and running the
query before analyzing that table.
Below is
    1.  An example query that shows the problem. It's joining a POINT
        from the table point_features with a MULTIPOLYGON from the
        table area_features.
    2.  The output from select * from postgis_full_version();
        and
    3.  A previous message from this list that I think might be related;
        since this is the same kind of query that was giving me
        "ERROR:  invalid join selectivity: inf"
        errors with RC4 when I had non-recently analyzed tables.
    Ron
=== My problem query
fli=# select *
         from userfeatures.point_features upf,
         userfeatures.area_features uaf
   where upf.the_geom && uaf.the_geom
     and intersects(upf.the_geom,uaf.the_geom)
     and uaf.featureid=18 limit 1
fli-# fli-# fli-# fli-# fli-# ;
  pointid | featureid | sessionid |   userid   | extid | label | iconid |                  the_geom                  | entity_id | areaid | featureid | session\
id |   userid   | extid | label | color | bordercolor |        \
   the_geom        \
     3391 |        20 |         0 | 1635480986 | -1    |       |      1 | 010100000018E29102631355C0606B040DBF743E40 |     29646 |     57 |        18 |        \
  0 | 1635480986 |       |       | green | green       | 0106000000010000000103000000010000002300000001ACAD4CE01255C02B7ED6AE7A723E407E0D4B0DFB1255C0E0E5C5FE7D\
723E40BC2EF520151355C01929CF1E96723E403A4C21872D1355C049D49A21C2723E40B9F3C54F431355C0A4E22E5600733E40F87B94A4551355C0DC5692584E733E40185C35D1631355C054C75129\
A9733E40E05C364A6D1355C00D80FD4A0D743E407F7566B2711355C08C147FE476743E40929B6ADE701355C07F9AF4E6E1743E40C34A68D66A1355C0771F9D354A753E40F85FB5D55F1355C070954D\
CEAB753E40615C9048501355C06A33E0F002763E40537FF7C73C1355C067541A444C763E4035A3C713261355C0E9D49DF684763E4006B55C0B0D1355C005D8A1DAAA763E40E74FFCA4F21255C0833A\
627BBC763E407C938711DA1255C0EBECE119C3763E40FF31EA50BF1255C03685F2C9BF763E40C110403DA51255C0FD41E9A9A7763E4043F313D78C1255C0CD961DA77B763E40C44B6F0E771255C072\
8889723D763E4085C3A0B9641255C03A142670EF753E4065E3FF8C561255C0C2A3669F94753E409DE2FE134D1255C009EBBA7D30753E40FEC9CEAB481255C08A5639E4C6743E40EBA3CA7F491255C0\
97D0C3E15B743E40BAF4CC874F1255C09F4B1B93F3733E4085DF7F885A1255C0A6D56AFA91733E401CE3A4156A1255C0AC37D8D73A733E402AC03D967D1255C0AF169E84F1723E40489C6D4A941255\
C02D961AD2B8723E40778AD852AD1255C0119316EE92723E4096EF38B9C71255C09330564D81723E4001ACAD4CE01255C02B7ED6AE7A723E40
(1 row)
fli=#
fli=#
=========postgis_full_version()
fli=# select * from postgis_full_version();
  POSTGIS="1.0.0RC6" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
(1 row)
fli=#
==== possibly related earlier conversation, that I don't remember
==== the conclusion of.
(Re: [postgis-users] ERROR:  invalid join selectivity: inf)
strk at refractions.net wrote:
> Mark, can you look at this ?
> As a short-term workaround, in lwgeom_estimate.c line 100:
> #define REALLY_DO_JOINSEL 0
> --strk;
> On Fri, Mar 04, 2005 at 03:01:32AM -0800, Ron Mayer wrote:
>>Ok.. I think I can reproduce this:
>>>   fl# select * from rtgr.landpoly,userfeatures.areas
>>>       where rtgr.landpoly.the_geom && userfeatures.areas.the_geom;
>>pretty easily.
>>Every time I "truncate table userfeatures.areas", and insert
>>some areas; I'll get that error message until I "analyze areas".
>>Seems like a bug when the stastics generated by analyze thinks
>>that a table is empty while in reality it isn't.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
