[postgis-users] CVS: HEAD and 1.0 branch
Jean David TECHER davidtecher at yahoo.fr
Fri Apr 22 02:55:30 PDT 2005
Hi Sandro
Me and my frind Gerald spent lot of times to try resolving the problem ...
Fisrt of all , I spent all my last night to try compiling PostGIS CVS...Hard
very hard :-[ Oh  my god:-(
It's a good idea to compil postgis wiithout PG source but hard to maintain,
I think
It seems that LDFLAGS, CFLAGS doesn't work ...
Building has been done by these commands
cvs -d ..... co postgis
cd postgis
autoconf
configure --with-geos=/c/PostgreSQL/8.0.2/bin/geos-config --enable-autoconf
I have the following in my PATH
C:\PostgreSQL\8.0.2\bin;C:\PostgreSQL\8.0.2\lib;C:\PostgreSQL\8.0.2\lib\post
gresql so that's the reason why configure found proj and postgresql
My postgis.log is at the end of this mail
I tried on PG 8.0.2
First error, I got postgis can't find
pwd.h, inet.h, neti,net.h in
/c/PostgreSQL/8.0.2/inlcude/postgresql/server/port/win32 (pa
So I did a comparaison with PostGIS 1.0.0
EXCUSE ME IF THE CHANGES I DID ARE NOT NICE AND GOOD BUT IT IS THE ONLY
SOLUTION
I FOUND SINCE CFLAGS AND CPPFLAGS DON'T WORK (maybe a configure problem ...I
ddon't know)
So I added manually in lwgeom/Makefile
line 34:
override CFLAGS=
+= -O2 -Wall -Wmissing-prototypes -Wpointer-arith -fno-strict-aliasing -g -O
2 -fexceptions
line 63:
override CFLAGS +=  $(PGBEINCLUDES)
 $(PGBEINCLUDES)/port/win32 -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
lines 90,91,92:
$(SHLIB): $(OBJS)
 dlltool --export-all  --output-def lwgeom.def $(OBJS)
 dllwrap  -o liblwgeom.dll --dllname liblwgeom.dll  --def lwgeom.def $(OBJS)
$(SHLIB_LINK) -L/c/PostgreSQL/8.0.2/lib -lpostgres
I needed to do few changes to but using staticaly library libpq.a (SORRY)
lines 37,38;
pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
 $(CC) $(CFLAGS) $(PGBEINCLUDES) $(PGBEINCLUDES)/port/win32 $(OBJS)
PQunescapeBytea.o pgsql2shp.o /c/PostgreSQL/8.0.2/lib/libpq.a $(LDFLAGS) -o
============================= lwgeom/Makefile
# Configuration Directives
include ../Makefile.config
include ../Version.config
# Default missing CXX variable to c++
ifeq ($(CXX),)
 CXX = c++
endif
# Shared library parameters.
NAME=lwgeom
SHLIB           =
lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
SHLIB_MAJOR     = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
SHLIB_BARE      = lib$(NAME)$(DLSUFFIX)
SHLIB_LINK  =
MODULE_FILENAME = $(LPATH)/$(SHLIB)
# Postgis version and build date
POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
POSTGIS_LIB_VERSION =
$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
override CFLAGS
2 -fexceptions
override CFLAGS += -fPIC
#override CFLAGS += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
JTS_OBJ=lwgeom_nojts.o
ifeq ($(USE_GEOS),1)
 override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
 GEOS_RULES=detect_geos_version
 GEOS_WRAPPER=lwgeom_geos_wrapper.o
 JTS_OBJ=lwgeom_geos.o
 SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
endif
ifeq ($(USE_JTS),1)
 override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
 JTS_WRAPPER=lwgeom_jts_wrapper.o
 JTS_OBJ=lwgeom_jts.o
 SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
endif
ifeq ($(USE_PROJ),1)
 override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
 SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
endif
override CXXFLAGS := $(CFLAGS)
# memory debug for gcc 2.91, 2.95, 3.0 and 3.1
# for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
#override CXXFLAGS += -D__USE_MALLOC
# Add index selectivity to C flags
ifeq ($(USE_STATS),1)
 override CFLAGS += -DUSE_STATS
endif
SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
$(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o
lex.yy.o vsprintf.o
OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o
lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o
lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
lwgeom_triggers.o lwgeom_dump.o
#OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwpostgis.sql
OTHERS=y.output lwpostgis.sql ../lwpostgis.sql postgis_geos_version.h
# Makefile targets
all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
$(SHLIB): $(OBJS)
wktparse.tab.c: wktparse.y
 $(YACC) -vd -p lwg_parse_yy wktparse.y
 mv -f y.tab.c wktparse.tab.c
 mv -f y.tab.h wktparse.tab.h
lex.yy.c: wktparse.lex wktparse.tab.c
 $(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
lwgeom_geos.o: lwgeom_geos.c profile.h
lwgeom_jts.o: lwgeom_jts.c profile.h
lwgeom_nojts.o: lwgeom_nojts.c
lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
# Shared library stuff
../lwpostgis.sql: lwpostgis.sql
 cp lwpostgis.sql ..
lwpostgis.sql: lwpostgis.sql.in
 cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e
's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERS
ION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DAT
E@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
install: all install-lwgeom-lib install-lwgeom-scripts
install-lwgeom-scripts:
 @mkdir -p $(datadir)
 $(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
 $(INSTALL_DATA) ../spatial_ref_sys.sql $(datadir)/spatial_ref_sys.sql
#- This has been copied from postgresql and adapted
install-lwgeom-lib: $(SHLIB)
 @mkdir -p $(MODULE_INSTALLDIR)
 $(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
ifneq ($(PORTNAME), win)
ifneq ($(SHLIB), $(SHLIB_MAJOR))
 cd $(MODULE_INSTALLDIR) && \
 rm -f $(SHLIB_MAHOR) && \
 ln -sf $(SHLIB) $(SHLIB_MAJOR)
endif
ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
 rm -f $(SHLIB_BARE) && \
 ln -sf $(SHLIB) $(SHLIB_BARE)
endif
endif # not win
uninstall-lib:
 rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
 rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
 rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
detect_geos_version:
 sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
uninstall-lwgeom-scripts:
 rm -f $(datadir)/postgis/lwpostgis.sql
 rm -f $(datadir)/postgis/spatial_ref_sys.sql
uninstall: uninstall-lib uninstall-lwgeom-scripts
clean-lib:
 rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
clean distclean: clean-lib
 rm -f *.o *.so *.a test $(OTHERS)
maintainer-clean: clean
 rm  -f lex.yy.c wktparse.tab.c wktparse.tab.h
liblwgeom_sa.o: liblwgeom.c
 $(CC) -DSTANDALONE -o $@ -c $<
liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
 $(CC) -shared -o $@ $^
liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
 $(AR) -rc $@ $^
test: liblwgeom_sa.so liblwgeom_sa.a test.c
 $(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
tsort:
 lorder $(SA_OBJS) | tsort
===================================== postgis.log
make -C lwgeom
make[1]: Entering directory `/home/david/sources/PostGIS/postgis/lwgeom'
sh ../geos_version.sh /c/PostgreSQL/8.0.2 > postgis_geos_version.h
gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -fno-strict-aliasing -g -
O2 -fexceptions -fPIC -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.0.0"' -DPOS
TGIS_SCRIPTS_VERSION='"0.3.0"' -DPOSTGIS_BUILD_DATE='"2005-04-22
09:36:56"' -I/c/PostgreSQL/8.0.2/include -DUSE_GEOS -I/c/PostgreSQL/8.0.2/bi
n/../include -DUSE_PROJ  -I/c/PostgreSQL/8.0.2/include/postgresql/server -I/
c/PostgreSQL/8.0.2/include/postgresql/server/port/win32 -DAUTOCACHE_BBOX=1
-DUSE_STATS   -c -o measures.o measures.c
cc1.exe: warning: -fPIC ignored for target (all code is position
independent)
-DUSE_STATS   -c -o box2d.o box2d.c
independent)
-DUSE_STATS   -c -o ptarray.o ptarray.c
independent)
-DUSE_STATS   -c -o lwgeom_api.o lwgeom_api.c
independent)
-DUSE_STATS   -c -o lwgeom.o lwgeom.c
independent)
-DUSE_STATS   -c -o lwpoint.o lwpoint.c
independent)
-DUSE_STATS   -c -o lwline.o lwline.c
independent)
-DUSE_STATS   -c -o lwpoly.o lwpoly.c
independent)
-DUSE_STATS   -c -o lwmpoint.o lwmpoint.c
independent)
-DUSE_STATS   -c -o lwmline.o lwmline.c
independent)
-DUSE_STATS   -c -o lwmpoly.o lwmpoly.c
independent)
-DUSE_STATS   -c -o lwcollection.o lwcollection.c
independent)
g++ -O2 -Wall -Wmissing-prototypes -Wpointer-arith -fno-strict-aliasing -g -
  -c -o lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
cc1plus.exe: warning: -fPIC ignored for target (all code is position
   independent)
-DUSE_STATS   -c -o wktunparse.o wktunparse.c
independent)
-DUSE_STATS   -c -o lwgparse.o lwgparse.c
independent)
-DUSE_STATS   -c -o wktparse.tab.o wktparse.tab.c
independent)
-DUSE_STATS   -c -o lex.yy.o lex.yy.c
independent)
lex.yy.c:3044: warning: `yyunput' defined but not used
-DUSE_STATS   -c -o vsprintf.o vsprintf.c
independent)
vsprintf.c:131: warning: no previous prototype for `vasprintf'
vsprintf.c:147: warning: no previous prototype for `asprintf'
-DUSE_STATS   -c -o liblwgeom.o liblwgeom.c
independent)
-DUSE_STATS   -c -o lwgeom_pg.o lwgeom_pg.c
independent)
-DUSE_STATS   -c -o lwgeom_debug.o lwgeom_debug.c
independent)
-DUSE_STATS   -c -o lwgeom_spheroid.o lwgeom_spheroid.c
independent)
-DUSE_STATS   -c -o lwgeom_ogc.o lwgeom_ogc.c
independent)
-DUSE_STATS   -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
independent)
-DUSE_STATS   -c -o lwgeom_geos.o lwgeom_geos.c
independent)
-DUSE_STATS   -c -o lwgeom_inout.o lwgeom_inout.c
independent)
-DUSE_STATS   -c -o lwgeom_estimate.o lwgeom_estimate.c
independent)
-DUSE_STATS   -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
independent)
-DUSE_STATS   -c -o lwgeom_gist.o lwgeom_gist.c
independent)
-DUSE_STATS   -c -o lwgeom_btree.o lwgeom_btree.c
independent)
-DUSE_STATS   -c -o lwgeom_transform.o lwgeom_transform.c
independent)
-DUSE_STATS   -c -o stringBuffer.o stringBuffer.c
independent)
-DUSE_STATS   -c -o lwgeom_box.o lwgeom_box.c
independent)
-DUSE_STATS   -c -o lwgeom_box3d.o lwgeom_box3d.c
independent)
-DUSE_STATS   -c -o lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
independent)
-DUSE_STATS   -c -o lwgeom_chip.o lwgeom_chip.c
independent)
-DUSE_STATS   -c -o lwgeom_svg.o lwgeom_svg.c
independent)
-DUSE_STATS   -c -o lwgeom_gml.o lwgeom_gml.c
independent)
-DUSE_STATS   -c -o lwgeom_triggers.o lwgeom_triggers.c
independent)
-DUSE_STATS   -c -o lwgeom_dump.o lwgeom_dump.c
independent)
dlltool --export-all  --output-def lwgeom.def measures.o box2d.o ptarray.o
lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o
lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o  wktunparse.o lwgparse.o
wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o
lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o
lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o
lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o
wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o
lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o
lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o
lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o
stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o
lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o
wgeom_dump.o  -lstdc++ -L/c/PostgreSQL/8.0.2/lib -lgeos -L/c/PostgreSQL/8.0.
2/bin/../lib -lproj -L/c/PostgreSQL/8.0.2/lib -lpostgres
Info: resolving _pj_errno by linking to __imp__pj_errno (auto-import)
Info: resolving _pj_release by linking to __imp__pj_release (auto-import)
cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.0:g;s:@POSTGIS_VERSION@:1.0
USE_GEOS=1 USE_PROJ=1
USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.0:g;s/@POSTGIS_BUILD_DATE@/200
5-04-22 09:36:56/g' | grep -v '^#' > lwpostgis.sql
cp lwpostgis.sql ..
make[1]: Leaving directory `/home/david/sources/PostGIS/postgis/lwgeom'
make -C loader
make[1]: Entering directory `/home/david/sources/PostGIS/postgis/loader'
gcc -g -Wall -I.. -O2 -Wall -Wmissing-prototypes -Wpointer-arith -fno-strict
-aliasing -I/c/PostgreSQL/8.0.2/include/postgresql/server -I/c/PostgreSQL/8.
0.2/include/postgresql/server/port/win32 -DUSE_VERSION=80   -c -o shpopen.o
shpopen.c
shpopen.c:176: warning: `rcsid' defined but not used
0.2/include/postgresql/server/port/win32 -DUSE_VERSION=80   -c -o dbfopen.o
dbfopen.c
dbfopen.c:200: warning: `rcsid' defined but not used
0.2/include/postgresql/server/port/win32 -DUSE_VERSION=80   -c -o getopt.o
getopt.c
getopt.c:115: warning: conflicting types for built-in function `strncmp'
getopt.c:602: warning: no previous prototype for `getopt'
shp2pgsql.o shp2pgsql.c
0.2/include/postgresql/server/port/win32 -DUSE_VERSION=80 shpopen.o
dbfopen.o getopt.o shp2pgsql.o  -o shp2pgsql.exe
0.2/include/postgresql/server/port/win32 -DUSE_VERSION=80 -I/c/PostgreSQL/8.
0.2/include -c pgsql2shp.c
pgsql2shp.c: In function `parse_commandline':
pgsql2shp.c:2290: warning: implicit declaration of function `getopt'
0.2/include/postgresql/server -I/c/PostgreSQL/8.0.2/include/postgresql/serve
r/port/win32 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o pgsql2shp.o
/c/PostgreSQL/8.0.2/lib/libpq.a  -o pgsql2shp.exe
make[1]: Leaving directory `/home/david/sources/PostGIS/postgis/loader'
make -C utils
make[1]: Entering directory `/home/david/sources/PostGIS/postgis/utils'
chmod +x postgis_restore.pl profile_intersects.pl test_estimation.pl
test_joinestimation.pl
make[1]: Leaving directory `/home/david/sources/PostGIS/postgis/utils'
make -C doc
make[1]: Entering directory `/home/david/sources/PostGIS/postgis/doc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/david/sources/PostGIS/postgis/doc'
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050422/b1ee8d85/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050422/b1ee8d85/attachment-0001.obj>
