[postgis-users] Building PostGIS from Sunday CVS..without PostgreSQL Sources...OK ! ! !
strk at refractions.net strk at refractions.net
Sun Apr 24 16:44:49 PDT 2005
On Sun, Apr 24, 2005 at 07:39:38PM +0200, Jean David TECHER wrote:
> Hi Sandro and PostGIS'ers,
> Last Sunday, I decided to compil PostGIS from CVS (form sunday in the afternoon)...
> Since the goal is to build PostGIS WITHOUT PostgreSQL sources but from the binairies installed on the computer
> the tests on Windows for me is OK...Successfull...I did it for PG 8.0.2, Geos 2.1.1 and Proj 4.4.9
Good news!
Weird I didn't change anything since your worried mails ;)
> The only changes -I had to do - were to make few changes on:
> -1/ postgis/Makefile.config.in
> - 2/postgis/lwgeom/Makefile
> - 3/postgis/loader/Makefile
> For each file, I used
> ifeq ($(findstring MINGW,$(MSYSTEM)),MINGW)
>      XXXXXXXXX
> else
>      XXXXXXXXXX
> endif
I'd put the XXXXXX all in Makefile.config.in.
> The changes in files are at the end of this files (sorry, I didn't at enough times to make patch... :-[ ....)
> Since i'm not at job on Monday but Tuesday, I will do a resume doc next Tuesday
> NOTICE: For creating postgis doc, I need to have docbook-xslt-stylesheets, xlstproc and icon.dll installed on Windows..Nevermind
> Just 3 downloading to do.
> cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis login
> cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis co postgis
> cd postgis
> autoconf
> configure --enable-autotconf --with-geos=`which geos-config`
If geos-config is in your PATH, which is what you expect using which, there should be
no need to be explicit. A simple --with-geos should work.
> make
> make install
> cd regress
> make
> Regression Tests, Loading some data with the laoder (...) work fine...
Thanks! See you on Tuesday with patches then :)
--strk;
> ========================================[postgis/Makefile.config.in ]==============================================================
> # Configuration Directives
> # We recommend that you install the Proj4 and GEOS libraries
> # referenced below to get the most use out of your PostGIS
> # database.
> # Set USE_PROJ to 1 for Proj4 reprojection support (recommended)
> # Reprojection allows you to transform coordinate systems
> # in the database with the Transform() function.
> # Download from: http://www.remotesensing.org/proj
> USE_PROJ=@USE_PROJ@
> PROJ_DIR=@PROJ_DIR@
> # Set USE_GEOS to 1 for GEOS spatial predicate and operator
> # support (recommended).
> # GEOS installation directory defaults to /usr/local,
> # set GEOS_DIR environment variable to change it.
> # GEOS allows you to do exact topological tests, such as
> # Intersects() and Touches(), as well as geometry operations,
> # such as Buffer(), GeomUnion() and Difference().
> # Download from: http://geos.refractions.net
> USE_GEOS=@USE_GEOS@
> GEOS_DIR=@GEOS_DIR@
> # Set USE_JTS to 1 if you have libjts installed.
> USE_JTS=0
> JTS_INCLUDES=@JTS_INCLUDES@
> JTS_LIBDIR=@JTS_LIBDIR@
> # Set USE_STATS to 1 for new GiST statistics collection support
> # Note that this support requires additional columns in
> # GEOMETRY_COLUMNS, so see the list archives for info or
> # install a fresh database using postgis.sql.
> # This option is useless for builds against PGSQL>=80 (stats
> # are always gathered in that case, and you don't need additional
> # columns in geometry_columns).
> USE_STATS=1
> # Set AUTOCACHE_BBOX to 0 if you want finer control over
> # bounding box computation and caching for your geometries.
> # If you do, bbox computattion strategies are listed in
> # the file lwgeom/BBOXCACHE_BEHAVIOURS, but don't expect
> # them to be easy nor consistent.
> AUTOCACHE_BBOX=1
> # Set USE_ICONV to 1 if you want the loader (shp2pgsql)
> # to support UTF-8 output.
> USE_ICONV=0
> # PGSQL
> PGCONFIG=@PGCONFIG@
> PGFEINCLUDES=@PGFEINCLUDES@
> PGBEINCLUDES=@PGBEINCLUDES@ @PGBEINCLUDES@/port @PGBEINCLUDES@/port/win32 @PGBEINCLUDES@/port/win32/arpa
> else
> PGFELIBS=@PGFELIBS@
> endif
> # Docbook
> XSLBASE=@XSLBASE@
> # Compilers
> CC=@CC@
> CXX=@CXX@
> # Other programs
> FLEX=@FLEX@
> YACC=@YACC@
> INSTALL=@INSTALL@ -c
> INSTALL_DATA=$(INSTALL) -m 644
> INSTALL_BIN=$(INSTALL) -m 755
> INSTALL_LIB=$(INSTALL) -m 755
> # PATHS
> prefix=@prefix@
> exec_prefix=@exec_prefix@
> bindir=@bindir@
> datadir=@datadir@
> mandir=@mandir@
> docdir=@docdir@
> libdir=@libdir@
> libexecdir=@libexecdir@
> MODULE_INSTALLDIR=@MODULE_INSTALLDIR@
> LPATH=@LPATH@
> # DLL
>  DLSUFFIX=.dll
>  DLFLAGS=@DLFLAGS@
> else
>  DLSUFFIX=@DLSUFFIX@
>  DLFLAGS=@DLFLAGS@
> endif
> # END OF CONFIGURATION
> # Use JTS instead of GEOS if available
> ifeq ($(USE_JTS),1)
>  USE_GEOS=0
> endif
> # Test the version string and set the USE_VERSION macro
> # appropriately.
> VERSION=$(shell $(PGCONFIG) --version)
> ifneq ($(findstring 7.1,$(VERSION)),)
>  USE_VERSION=71
> else
>  ifneq ($(findstring 7.2,$(VERSION)),)
>   USE_VERSION=72
>  else
>   ifneq ($(findstring 7.3,$(VERSION)),)
>    USE_VERSION=73
>   else
>    ifneq ($(findstring 7.4,$(VERSION)),)
>     USE_VERSION=74
>    else
>     USE_VERSION=80
>    endif
>   endif
>  endif
> endif
> ========================================[ postgis/lwgeom/Makefile ]==============================================================
> include ../Makefile.config
> include ../Version.config
> # Default missing CXX variable to c++
> ifeq ($(CXX),)
>  CXX = c++
> endif
> # Shared library parameters.
> NAME=lwgeom
> SHLIB           = lib$(NAME).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)$(DLSUFFIX)
> SHLIB_MAJOR     = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
> SHLIB_BARE      = lib$(NAME)$(DLSUFFIX)
> SHLIB_LINK  =
> else
> SHLIB           = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> SHLIB_LINK  = $(DLFLAGS)
> endif
> MODULE_FILENAME = $(LPATH)/$(SHLIB)
> # Postgis version and build date
>  POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION) USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
>  POSTGIS_LIB_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
>  POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
> else
> endif
> override CFLAGS += -g -O2 -fexceptions
> override CFLAGS += -fPIC
> #override CFLAGS += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
> override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
> override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
> override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
> override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
> JTS_OBJ=lwgeom_nojts.o
> ifeq ($(USE_GEOS),1)
>  override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
>  GEOS_RULES=detect_geos_version
>  GEOS_WRAPPER=lwgeom_geos_wrapper.o
>  JTS_OBJ=lwgeom_geos.o
>  SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
> endif
> ifeq ($(USE_JTS),1)
>  override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
>  JTS_WRAPPER=lwgeom_jts_wrapper.o
>  JTS_OBJ=lwgeom_jts.o
>  SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
> endif
> ifeq ($(USE_PROJ),1)
>  override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
>  SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
> endif
> override CFLAGS += $(PGBEINCLUDES) -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
> override CXXFLAGS := $(CFLAGS)
> # memory debug for gcc 2.91, 2.95, 3.0 and 3.1
> # for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
> #override CXXFLAGS += -D__USE_MALLOC
> # Add index selectivity to C flags
> ifeq ($(USE_STATS),1)
>  override CFLAGS += -DUSE_STATS
> endif
> SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o $(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o
> OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o
> #OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwpostgis.sql
> OTHERS=y.output lwpostgis.sql ../lwpostgis.sql postgis_geos_version.h
> # Makefile targets
> all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
> #------------ It's for Win32 -----------------------------------
> $(SHLIB): $(OBJS)
>  dlltool --export-all  --output-def lwgeom.def $(OBJS)
>  dllwrap  -o $@ --dllname $@ --def lwgeom.def $(OBJS) $(SHLIB_LINK) -L$(shell pg_config --libdir) -lpostgres
>  dlltool --dllname $@  --def lwgeom.def --output-lib liblwgeom.a
> else
>  $(CC) $(SHLIB_LINK) -o $(SHLIB) $(OBJS)
> endif
> wktparse.tab.c: wktparse.y
>  $(YACC) -vd -p lwg_parse_yy wktparse.y
>  mv -f y.tab.c wktparse.tab.c
>  mv -f y.tab.h wktparse.tab.h
> lex.yy.c: wktparse.lex wktparse.tab.c
>  $(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
> lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
> lwgeom_geos.o: lwgeom_geos.c profile.h
> lwgeom_jts.o: lwgeom_jts.c profile.h
> lwgeom_nojts.o: lwgeom_nojts.c
> lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
> # Shared library stuff
> ../lwpostgis.sql: lwpostgis.sql
>  cp lwpostgis.sql ..
> lwpostgis.sql: lwpostgis.sql.in
>  cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> install: all install-lwgeom-lib install-lwgeom-scripts
> install-lwgeom-scripts:
>  @mkdir -p $(datadir)
>  $(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
>  $(INSTALL_DATA) ../spatial_ref_sys.sql $(datadir)/spatial_ref_sys.sql
> #- This has been copied from postgresql and adapted
> install-lwgeom-lib: $(SHLIB)
>  @mkdir -p $(MODULE_INSTALLDIR)
>  $(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
> ifneq ($(PORTNAME), win)
> ifneq ($(SHLIB), $(SHLIB_MAJOR))
>  cd $(MODULE_INSTALLDIR) && \
>  rm -f $(SHLIB_MAHOR) && \
>  ln -sf $(SHLIB) $(SHLIB_MAJOR)
> endif
> ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
>  rm -f $(SHLIB_BARE) && \
>  ln -sf $(SHLIB) $(SHLIB_BARE)
> endif
> endif # not win
> uninstall-lib:
>  rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
>  rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
>  rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
> detect_geos_version:
>  sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
> uninstall-lwgeom-scripts:
>  rm -f $(datadir)/postgis/lwpostgis.sql
>  rm -f $(datadir)/postgis/spatial_ref_sys.sql
> uninstall: uninstall-lib uninstall-lwgeom-scripts
> clean-lib:
>  rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
> clean distclean: clean-lib
>  rm -f *.o *.so *.a test $(OTHERS)
> maintainer-clean: clean
>  rm  -f lex.yy.c wktparse.tab.c wktparse.tab.h
> liblwgeom_sa.o: liblwgeom.c
>  $(CC) -DSTANDALONE -o $@ -c $<
> liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
>  $(CC) -shared -o $@ $^
> liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
>  $(AR) -rc $@ $^
> test: liblwgeom_sa.so liblwgeom_sa.a test.c
>  $(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
> tsort:
>  lorder $(SA_OBJS) | tsort
> ========================================[ postgis/loader/Makefile ] ===============================================================
> # PostGIS Loader Makefile
> SHELL = /bin/sh
> subdir = contrib/postgis/loader
> EXE =
> UNAME = $(shell uname)
> ifeq ($(findstring CYGWIN,$(UNAME)),CYGWIN)
>  EXE = .exe
> endif
> ifeq ($(findstring MINGW,$(UNAME)),MINGW)
>  EXE = .exe
> endif
> OBJS = shpopen.o dbfopen.o getopt.o
> ifeq ($(USE_ICONV),1)
>  override CFLAGS += -DUSE_ICONV
> endif
> override CFLAGS := -g -Wall -I.. $(CFLAGS) -DUSE_VERSION=$(USE_VERSION)
> all: shp2pgsql$(EXE) pgsql2shp$(EXE)
> pgsql2shp.o: pgsql2shp.c
>  $(CC) $(CFLAGS) $(PGFEINCLUDES) -c $<
> pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
>  $(CC) $(CFLAGS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS) $(shell pg_config --libdir)/libpq.a -o $@
> else
>  $(CC) $(CFLAGS) $(PGFELIBS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS) -o $@
> endif
> shp2pgsql$(EXE): $(OBJS) shp2pgsql.o
>  $(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
> install: all
>  @mkdir -p $(bindir)
>  $(INSTALL_BIN) pgsql2shp$(EXE) $(bindir)/pgsql2shp$(EXE)
>  $(INSTALL_BIN) shp2pgsql$(EXE) $(bindir)/shp2pgsql$(EXE)
> uninstall:
>  rm -f $(bindir)/pgsql2shp$(EXE)
>  rm -f $(bindir)/shp2pgsql$(EXE)
> clean:
>  rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE) pgsql2shp$(EXE)
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> postgis-users mailing list
