Fwd: Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Jaakko Kahkonen jaakko.kahkonen at fgi.fi
Thu Aug 4 03:30:07 PDT 2005
It helped, thanks!
Jaakko
Christo Du Preez wrote:
> Try leaving out doc. I have experienced problems when trying to include
> doc.
> Jaakko Kahkonen wrote:
>> Hi,
>> I have a new installation of Gentoo-Linux and problems with
>> postgis-1.0.1_p20050727. Postgresql-8.0.3 is installed.
>> jakpc ~ # emerge -puv postgis
>> These are the packages that I would merge, in order:
>> Calculating dependencies       ...done!
>> [ebuild  N    ] dev-db/postgis-1.0.1_p20050727  +doc +geos +proj 0 kB [1]
>> Total size of downloads: 0 kB
>> Portage overlays:
>>  [1] /usr/local/portage
>> jakpc ~ # emerge -uv postgis
>> >>> emerge (1 of 1) dev-db/postgis-1.0.1_p20050727 to /
>> >>> md5 files   ;-) postgis-1.0.1_p20050727.ebuild
>> >>> md5 files   ;-) files/digest-postgis-1.0.1_p20050727
>> >>> md5 src_uri ;-) postgis-cvs-1.0.1_p20050727.tar.gz
>> >>> Unpacking source...
>> 1.0.1_p20050727
>> >>> Unpacking postgis-cvs-1.0.1_p20050727.tar.gz to
>> /var/tmp/portage/postgis-1.0
>> .1_p20050727/work
>> >>> Source unpacked.
>>  * Building doc with xsl-stylesheets-1.68.1-r1
>>  * econf: updating postgis-cvs/config.guess with
>> /usr/share/gnuconfig/config.gue
>> ss
>>  * econf: updating postgis-cvs/config.sub with
>> /usr/share/gnuconfig/config.sub
>> ./configure --prefix=/usr --host=i686-pc-linux-gnu
>> --mandir=/usr/share/man --inf
>> odir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc
>> --localstatedir=/var
>> /lib --build=i686-pc-linux-gnu --enable-autoconf
>> --with-maxbackends=1024 --with-
>> geos=/usr/bin/geos-config --with-proj=/usr
>>  * doc will be built
>> ./configure
>> make -C utils
>> make[1]: Entering directory
>> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postg
>> is-cvs/utils'
>> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
>> profile_inte
>> rsects.pl test_estimation.pl test_joinestimation.pl
>> make[1]: Leaving directory
>> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgi
>> s-cvs/utils'
>> ./config.status
>> make: ./config.status: Command not found
>> make: *** [Makefile.config] Error 127
>> !!! ERROR: dev-db/postgis-1.0.1_p20050727 failed.
>> !!! Function src_compile, Line 63, Exitcode 2
>> !!! Error: emake failed
>> !!! If you need support, post the topmost build error, NOT this status
>> message.
>> jakpc ~ #
>> What should I try to do to fix this?
