[postgis-users] error in installation
Claude Philipona claude.philipona at camptocamp.com
Fri Aug 19 07:00:55 PDT 2005
pouruqoi ne l'envois-tu pas vers les paquest C2C?
Claude
Daniel wrote:
> Hello,
> A compliant debian package exists for PostGIS. However, it seems that it
> has some little bugs and/or differences with standard postgreql
> installation, which could lead to compilation problems with other
> softwares/contribs.
> After testing such an install, I saw that pg_config wasn't installed
> properly. Or, it is used for locating some  pg installed files.
> Furthermore, I didn't saw any -dev package ...
> At this time, I still prefer compiling myself with options that exactly
> fit my needs ...
> Yours,
> dF
> orkun wrote:
>> hello
>> When I tried to install postgis. I encountered this error:
>> # ./configure --enable-autoconf
>> Using autoconf
>> checking for proj... /usr/bin/proj
>> configure: error:  Can't find (configured) PGSQL sources.
>> I had installed postgresql as debian package.
>> Could you possiblly tell me how I could overcome this problem?
>> regards
>> Ahmet Temiz
>> ______________________________________
>> XamimeLT - installed on mailserver for domain @deprem.gov.tr
>> Queries to: postmaster at deprem.gov.tr
>> The views and opinions expressed in this e-mail message are the
>> sender's own
>> and do not necessarily represent the views and the opinions of
>> Earthquake Research Dept.
>> of General Directorate of Disaster Affairs.
>> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
>> olarak T.C.
>> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
>> nitelikte degildir.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050819/ccded741/attachment.vcf>
