[postgis-users] shp2pgsql and multibyte shape files
strk at refractions.net strk at refractions.net
Sat Aug 20 01:29:10 PDT 2005
On Fri, Aug 19, 2005 at 01:54:47PM +0200, Jorg Heymans wrote:
> strk at refractions.net wrote:
> > Documentation contributions are welcome.
> > --strk;
> attached.
Ehmm.... the source document is the postgis.xml file distributed with postgis.
Best patches are those against the pgis_1_0 branch of CVS.
For head branch the USE_ICONV variable would be set by ./configure.
Note that in both cases USE_ICONV itself might fail (linking against
libiconv might be needed on some systems, and linkage might require
specific flags for other-then-GNU systems).
--strk;
PS: thanks :)
