[postgis-users] Buffer bug ?
Daniel daniel.faivre at camptocamp.com
Fri Aug 26 07:26:29 PDT 2005
The bug occurs with geos 2.1.4 too ...
Daniel wrote:
> As said in my last post, the problem come from the buffer() function.
> (the collect() only take 345 ms)
> I will try a geos update this afternoon and post the result here.
> Sincerely yours,
> dF
> Mark Cave-Ayland wrote:
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> Daniel
>>> Sent: 26 August 2005 13:13
>>> To: Mark Cave-Ayland (External)
>>> Cc: Arnaud Saint Léger; 'PostGIS Users Discussion'
>>> Subject: Re: [postgis-users] Buffer bug ?
>>> Hi,
>>> Thank u very much for your help. Here are precisions u requested:
>> (cut)
>>> 6) splitting of the request:
>>> 6.1) CREATE TABLE temp_lg_annee_bis AS SELECT * FROM lg_annee_bis
>>> WHERE lga_annee=2004 and lga_nat_cdn=2 and lga_var > -1; ---> 345
>>> milliseconds
>>> 6.2) buffer computing: the bug occur
>> Hi Daniel,
>> Well it doesn't look as if it's a database tuning problem. Can you
>> try and
>> isolate the whether it is the buffer() or the collect() which is
>> taking the
>> time by trying your query without the buffer(), e.g.
>>     BEGIN;
>>     CREATE TABLE temp_lg_annee_bis AS SELECT * FROM lg_annee_bis WHERE
>>     SELECT collect(lga_geom) FROM temp_lg_annee_bis GROUP BY lga_annee;
>>     ABORT;
>> If it is the buffer() which is causing the slowdown then it's definitely
>> worth trying upgrading to the latest GEOS release which is now 2.1.4.
>> Kind regards,
>> Mark.
>> WebBased Ltd
>> 17 Research Way
>> Tamar Science Park
>> Plymouth
>> PL6 8BT
>> T: +44 (0)1752 797131
>> F: +44 (0)1752 791023
>> W: http://www.webbased.co.uk
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050826/3a91601b/attachment.vcf>
