[postgis-users] Buffer bug ?
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Aug 26 08:33:27 PDT 2005
> -----Original Message-----
> From: Daniel [mailto:daniel.faivre at camptocamp.com]
> Sent: 26 August 2005 16:17
> To: Mark Cave-Ayland (External)
> Cc: 'PostGIS Users Discussion'; 'Arnaud Saint Léger'
> Subject: Re: [postgis-users] Buffer bug ?
(cut)
> Yes: I've just checked it again.
Hi Daniel,
OK. Another thing to check: is the resulting geometry from the collect()
valid? i.e. SELECT IsValid(collect(lga_geom) FROM temp_lg_annee_bis GROUP BY
lga_annee) returns true, since GEOS will only work on geometries where
IsValid(geom) is true.
Unfortunately I'm now away from work for at least a week, but I hope that
someone else on the list will be able to give you some help in the meantime.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
