[postgis-users] Calculate area shperoid
Brent Wood pcreso at pcreso.com
Fri Aug 26 17:11:14 PDT 2005
--- luzbrigitte <luzbrigitte at hotmail.com> wrote:
> Hi, anyone knows how can I calculate area to polygons ?  We work with WGS84
> system,  srid -1 and PostGis 0.9
If your SRID is -1, then Postgis doesn't know whether the units are
degrees/metres etc. If your data is lat/long degrees wgs84, try using a SRID
like 4326 instead. That allows the transform function to correctly reproject
your lat/long coords to the equal area projection you want to derive your area
result from.
Brent
