[postgis-users] Why does this take almost 3 hours?
Stephen Woodbridge woodbri at swoodbridge.com
Tue Aug 30 10:44:38 PDT 2005
Have you tried "contains() or touches()" instead of intersects() to see
if the algorithm is more efficient.
There might be a need for a special case in the code that deals with
point geometries because the solution is often significantly more
trivial. I haven't looked at the code, so it might already be doing this.
But for example, the point and polygon test should be approximately the
cost of one loop over the segments of the polygon to count how many of
them intersect a line segment from the point to a point outside the
extents of the polygon keeping the X value constant. An even count is
false and odd count is true, and you have to deal with a couple of
degenerate cases that are well defined, if the point falls on an edge(s)
or on a vertex(s). Using trivial reject of segments totally above/below
means the very few actual segments need to be tested.
-Steve
Ethan Alpert wrote:
> I need real intersection and queryByShape() produces the exact same
> selection as my postgis query.
> -e
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> strk at refractions.net
> Sent: Monday, August 29, 2005 4:46 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Why does this take almost 3 hours?
> Does queryByShape() detect real intersection?
> I bet the index has nothing to do with this, it's just
> the Intersects() function taking your time. Try to take
> it off.
> Then, if you can, try using JTS instead of GEOS to compare performances
> (I can do this part for you if you send me source data).
> --strk;
> On Mon, Aug 29, 2005 at 03:14:20PM -0600, Ethan Alpert wrote:
>>Bill yes my nga_reg is 11 complex shapes.
>>What I don't understand is why queryByShape() using QIX files is SO
>>much better.
>>-e
>>Bill Binko
>>Sent: Monday, August 29, 2005 3:22 PM
>>On Mon, 29 Aug 2005, Ethan Alpert wrote:
>>>nga_reg is basically the world admin divided up into 11 distinct
>>>regions. My new_snaps table has 13543 records.
>>>2 hours and 39 minutes later pgsql2shp of the above query finished
>>>The above query's explain analyze is:
>>>spatialdb_sil0=> explain analyze  SELECT a.catalogid, b.cii_region,
>>>a.the_geom  FROM new_snaps a, nga_reg b WHERE a.the_geom &&
> b.the_geom
>>>AND intersects(a.the_geom, b.the_geom);
>>QUERY
>>>PLAN
>>> Nested Loop  (cost=0.00..67.41 rows=4966 width=273) (actual
>>>time=11.040..2397944.885 rows=13416 loops=1)
>>>   Join Filter: intersects("inner".the_geom, "outer".the_geom)
>>>   ->  Seq Scan on nga_reg b  (cost=0.00..1.11 rows=11 width=37)
>>(actual
>>>time=0.004..147.586 rows=11 loops=1)
>>>   ->  Index Scan using new_snaps_spatial on new_snaps a
>>>(cost=0.00..6.01 rows=1 width=268) (actual time=68.748..9599.432
>>>rows=3892 loops=11)
>>>         Index Cond: (a.the_geom && "outer".the_geom)
>>>         Filter: (a.the_geom && "outer".the_geom)
>>> Total runtime: 2397998.833 ms
>>How many shapes are in nga_reg?  When you say "basically the world
>>admin
>>divided into 11 districts", do you mean there are only 11 shapes?  If
>>so, how complex are the shapes?
>>There are two possibilities I can see where PostGIS would fail you in
>>this way.
>>One is that the nga_reg table is huge (lots of shapes). If that's the
>>case, then PostGIS should be driving the other direction (doing a seq
>>scan
>>on new_snaps and using the index on nga_reg).  If it's not, it is a
> poor
>>query plan and perhaps the PostGIS developers can help track that
>>down.
>>An easy way to test this is to remove the index on new_snaps and redo
>>your explain (and your timing test).
>>The alternative is that you have 11 (or some other small number of)
>>very
>>large, very complicated shapes.  If that's the case, your indexes are
>>not going to help you since you'll end up doing an expensive
>>intersect() operation for each pair, and most new_snaps's bouding
>>boxes will fall within the large shape's bounding boxes.  If the
>>shapes are Collections,
>>you might try "exploding" them so that you can get better use of the
>>bounding boxes.
>>I hope this helps
>>Bill
>>_______________________________________________
>>postgis-users mailing list postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
