[postgis-users] Making shp2pgsql using iconv in /usr/local?
Mike Leahy mgleahy at alumni.uwaterloo.ca
Thu Dec 1 03:29:27 PST 2005
Good morning.
cvs branch 'pgis_1_0' compiled fine for me using the flags as you indicated:
   ICONV_CFLAGS="-DLIBICONV_PLUG" make
I figure you're right about LIBICONV_PLUG forcing the use of glibc
instead of libiconv.  If it is defined, the lines that look like
   "#define iconv* libiconv*"
are all skipped in iconv.h, and shp2pgsql compiles nicely.  Presumably
those define statements would be needed in the absence of glibc.
Mike
strk at refractions.net wrote:
> On Wed, Nov 30, 2005 at 10:01:39PM -0500, Mike Leahy wrote:
>> Hello again,
>> On second thought, a cleaner solution to this is to add "#define
>> LIBICONV_PLUG" just before the line with "#include <iconv.h>" in
>> shp2pgsql.c.  This essentially accomplishes the same (i.e., avoids
>> redefinition of the libiconv_* functions), and without hacking-up the
>> iconv.h like I did in my previous.  I tried to do this via the make
>> command like so:
>> as well as
>>  CFLAGS="-DLIBICONV_PLUG" make loaderdumper
>> but that had no effect (is this right the right way?).  I think part of
>> the issue here is that CFLAGS is reset at the start of loader/Makefile,
>> so any CFLAGS (or LDFLAGS) options that are supplied when executing make
>> are wiped by the time the loader source is compiled.
> Setting CFLAGS in the environment works fine with postgis-head.
> The CFLAGS reset happens in PGSQL_SRC/Makefile.global, there's
> no easy fix for 1.0.
>> Should LIBICONV_PLUG be an option that is just always enabled when
>> USE_ICONV=1, or should it be optional?  Everything worked fine when I
>> added "LIBICONV_PLUG = 1" in Makefile.config, then the following lines
>> in loader/Makefile:
>> ifeq ($(LIBICONV_PLUG),1)
>> 	override CFLAGS += -DLIBICONV_PLUG
>> endif
> I guess that LIBICONV_PLUG forces you to use the glibc version
> rather then libiconv, right ? This would fail on system with
> libiconv *only* external to libc, correct ?
> Mapserver solution was to always link against libiconv if present and let
> header file inclusion determine which version to use.
> I've committed a patch for the 1.0 branch allowing you to specify
> ICONV_LDFLAGS and ICONV_CFLAGS, please check if that would do for
> you. Your choice would be:
> Original user choice would be something like:
> 	ICONV_CFLAGS="-I/usr/local/include" \
> 		ICONV_LDFLAGS="-L/usr/local/lib -liconv" make
> Let me know if this makes it.
> I'd reserve changes in the HEAD branch for later, to allow for
> autodetection of cases in which external lib only supports iconv.
> Filing a bug report would help keeping track of this.
> Thanks.
> --strk;
>> Anyway, that's all for now.
>> Regards,
>> Mike
>> Mike Leahy wrote:
>>> Hey there,
>>> I think this problem might be related to a bug found with MapServer a
>>> while back: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
>>> I tried commenting out the following lines in /usr/local/include/iconv.h
>>> (version 1.10), and PostGIS compiled without errors:
>>> 45: //#undef iconv_t
>>> 46: //#define iconv_t libiconv_t
>>> 70: //#define iconv_open libiconv_open
>>> 80: //#define iconv libiconv
>>> 86: //#define iconv_close libiconv_close
>>> 96: //#define iconvctl libiconvctl
>>> 119: //#define iconvlist libiconvlist
>>> I have no idea if this breaks anything...I just figured it was related
>>> to conflicting libraries as suggested in the MapServer bug referenced
>>> above.
>>> I'm running FC4, with the most recent upgrades.
>>> I hope this helps.
>>> Mike
>>> Larry Shaffer wrote:
>>>> strk,
>>>> Sorry for the lack of info on my part. I'd like to get this working, but
>>>> it's no big thing until I get ready to install the upcoming PostGIS 1.0.6
>>>> version, as this is a brand new setup (PostgreSQL and all) with no real
>>>> data installed into yet.
>>>> Make for PostGIS works fine with USE_ICONV ?= 0
>>>> My src path is /usr/local/src/postgresql-8.1.0/contrib/postgis
>>>> These are the values in the PGISSRC/Makefile.config:
>>>> USE_PROJ ?= 1
>>>> PROJ_DIR ?= /usr/local
>>>> USE_GEOS ?= 1
>>>> GEOS_DIR ?= /usr/local
>>>> USE_JTS ?= 0
>>>> JTS_INCLUDES = /usr/local/include
>>>> JTS_LIBDIR = /usr/local/lib
>>>> USE_STATS=1
>>>> AUTOCACHE_BBOX ?= 1
>>>> PGSQL_SRC=/usr/local/src/postgresql-8.1.0
>>>> USE_ICONV ?= 1
>>>> (set to 0 for PostGIS make, then to 1 for shp2pgsql make)
>>>> LPATH=/usr/local/src/postgresql-8.1.0/contrib/postgis
>>>> What's in /usr/local/lib
>>>> libiconv_plug.so
>>>> libiconv.la
>>>> libiconv.so
>>>> libiconv.so.2
>>>> libiconv.so.2.2.0
>>>> What's in /usr/local/include
>>>> iconv.h
>>>> and whereis?
>>>> sh-2.05a# whereis libiconv
>>>> libiconv: /usr/local/lib/libiconv.so /usr/local/lib/libiconv.la
>>>> sh-2.05a# whereis iconv
>>>> iconv: /usr/bin/iconv /usr/local/bin/iconv /usr/include/iconv.h /usr/
>>>> share/man/man1/iconv.1.gz /usr/share/man/man3/iconv.3.gz
>>>> (Where is /usr/local/include/iconv.h? It *does* exist in /usr/local/
>>>> include. This could be the problem...)
>>>> Running  iconv -l  for /usr and /usr/local provides positive results of
>>>> listing encodings (i.e. both are working).
>>>> sh-2.05a# /usr/bin/iconv --version
>>>> iconv (GNU libc) 2.2.5
>>>> Copyright (C) 2002 Free Software Foundation, Inc.
>>>> Written by Ulrich Drepper.
>>>> sh-2.05a# /usr/local/bin/iconv --version
>>>> iconv (GNU libiconv 1.9)
>>>> Copyright (C) 2000-2002 Free Software Foundation, Inc.
>>>> Written by Bruno Haible.
>>>> I installed the libiconv-1.9.1 from GNU since it was a standalone.
>>>> Should I install the Standard C library (glibc-2.3.2) in /usr/local ? I
>>>> don't think the /usr/local extras before make command of shp2pgsql are
>>>> making a difference, so I don't think it's worth the effort right now.
>>>> See the following...
>>>> Here's the output from the /usr/local extras
>>>> (run from within contrib/postgis/loader)
>>>> sh-2.05a# LDFLAGS="-L/usr/local/lib -liconv" CFLAGS="-I/usr/local/
>>>> include" make shp2pgsql
>>>> make: `shp2pgsql' is up to date.
>>>> sh-2.05a# make clean
>>>> rm -f shpopen.o dbfopen.o getopt.o PQunescapeBytea.o shp2pgsql.o
>>>> pgsql2shp.o shp2pgsql pgsql2shp
>>>> gcc -g -Wall -I.. -I. -I/usr/local/src/postgresql-8.1.0/src/interfaces/
>>>> libpq -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -fno-
>>>> strict-aliasing -DUSE_ICONV -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/
>>>> etc"' -DUSE_VERSION=81 -I/usr/local/src/postgresql-8.1.0/src/include -
>>>> D_GNU_SOURCE  -I/usr/local  -c -o shpopen.o shpopen.c
>>>> shpopen.c:176: warning: `rcsid' defined but not used
>>>> D_GNU_SOURCE  -I/usr/local  -c -o dbfopen.o dbfopen.c
>>>> dbfopen.c:200: warning: `rcsid' defined but not used
>>>> D_GNU_SOURCE  -I/usr/local  -c -o getopt.o getopt.c
>>>> D_GNU_SOURCE  -I/usr/local  -c -o PQunescapeBytea.o PQunescapeBytea.c
>>>> D_GNU_SOURCE  -I/usr/local  -c -o shp2pgsql.o shp2pgsql.c
>>>> etc"' -DUSE_VERSION=81 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o
>>>> shp2pgsql.o -L/usr/local/src/postgresql-8.1.0/src/port -lstdc++  -L/usr/
>>>> local -Wl,-rpath,/usr/local/pgsql/lib -o shp2pgsql shp2pgsql.o: In
>>>> function `utf8':
>>>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1630:
>>>> undefined reference to `libiconv_open'
>>>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1648:
>>>> undefined reference to `libiconv'
>>>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1654:
>>>> undefined reference to `libiconv_close'
>>>> collect2: ld returned 1 exit status
>>>> make: *** [shp2pgsql] Error 1
>>>> and without the /usr/local extras... just 'make shp2pgsql'...
>>>> exactly the same results.
>>>> I don't think /usr/local/include/incov.h is being located. Either way,
>>>> it's failing to make when using the base install of Debian
>>>> [linus]$ uname -a
>>>> Linux linus 2.4.28-grsec+w+fhs6b+gr0501+nfs+++p4+c4+gr6b-v6.188 #1 SMP
>>>> Fri Jan 14 11:41:59 PST 2005 i686 unknown
>>>> Any help would be appreciated. Thanx.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
