[postgis-users] PostGis 8.1 - error with "using unique"
jerome jerome.caba at vanoise.com
Thu Dec 1 07:43:15 PST 2005
Thanks Mark,
>>$layer->set("data",$colonne_geometrique." from ".$table_choisie." as
>>foo");
>Please see this post here:
>http://postgis.refractions.net/pipermail/postgis-users/2005-November/010087.
>html. Also I don't see any "using unique" clause in your data statement. It
>should read something like:
Re-oupss, sorry, another error, in my code I have :
$layer->set("data",$colonne_geometrique." from ".$table_choisie." as foo
using unique geometry_columns.srid using SRID=".$srid);
>$layer->set("data", $colonne_geometrique." from ".$table_choisie." using
>unique <id>");
>... where <id> is the name of your primary key. Since this is an issue with
>the Mapserver/PostGIS connector, you may get better assistance on the
>mapserver-users mailing list.
I have tried to write "select geo_unitealpage25 from unites_alpage as
foo using unique code_unitealpage" in SQL Manager.
the field "code_unitealpage" is my PK, like it's suggest in the forum.
Unfortunately ! I didn't think that this error is a mapserver error,
because, it's the same in SQL Manager or in pgAdmin.
Jerome Caba
