[postgis-users] avpgcon - workaround/fix
Robert Burgholzer rburghol at chesapeakebay.net
Fri Dec 2 11:26:04 PST 2005
This from the "WayBack Machine":
Don't know if anyone is still using avpgcon.avx, but I still use ArcView
3.3 a bit, and so use avpgcon. This fix relates to that.
When loading a shape from postgis an error is thrown when avpgcon tests
to see if the shape is within the current extent, i.e.:
SELECT gid, shapename, the_geom
FROM pg_table
WHERE
the_geom && GeometryFromText('BOX3D(-356801.233852
3928796.210200,649032.548074 4927586.338191)'::box3d,-1)
Seems that the newer version of geometryFromText don't like the Box3d,
however, if you simply change the "GeometryFromText" to "Transform", as
in :
FROM pg_table
WHERE
the_geom && transform('BOX3D(-356801.233852 3928796.210200,649032.548074
Everything appears to be hunky-dory.
Robert W. Burgholzer
Nonpoint Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
http://www.chesapeakebay.net/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051202/17e01c14/attachment.html>
