[postgis-users] Postgis JDBC Driver update
Johan Wehtje genwolf at gmail.com
Fri Dec 2 22:07:37 PST 2005
Paul,
 I followed your suggestions - and my pg logs show that what is happening is
that the client is querying for relations that are not schema qualified
therefore there are a whole lot of errors saying that
"relation <geom table name> does not exist". I have tried to create Postgis
Tables in the public schema but for wahtever reason Udig is not seeing them.
I do think that the problem lies with the older Postgis driver not
understanding schema's as the logged client requests that generate errors
are not schema qualified.
I tried a trivial JDBC connection using Coldfusion connected to a JDBC data
source. Queries like this:
<cfquery name="geomtest"     datasource="jdbc.env_db">
SELECT gid, tag, AsText(the_geom) as geostring from shapes.bompah3
</cfquery>
Generate the expected output.
I also tried area, centroid, intersection and a number of other queries and
all returned the expected results, all issued over a JDBC connection between
Postgres and Cold Fsuion.
I tried the same thing setting up a data source in OpenOffice 2.0 and
running Postgis Functions like area as queries against Postgis Tables over a
JDBC connection, and all queries returned the expected results.
In addition QGis on both windows and Linux (which uses an embedded Posgresql
C library) has no problems with any of the Postgresql/Postgis servers.
Could you give me the connection parameters to test instance and I will give
that a try, though being on a satellite connection I sometimes have trouble
with applications that have timeouts set below the latency to be expected on
such a connection.
Cheers
Johan Wehtje
On 12/3/05, Paul Ramsey <pramsey at refractions.net> wrote:
> Johan,
>    I have been following your emails on the udig list as well, and
> the fact that other users can connect to postgis fine indicates to me
> that the problem is likely not something as broad as a jdbc driver
> problem, or else everyone would be having troubles.
>    There is something particular about your setup which is the key,
> but it's hard to know what.  One thing you could do is turn on
> statement logging in postgresql.conf and watch the log while udig
> connects, see how far it gets, so you can see what return value it is
> choking on.  You could also try to write some trivial JDBC
> applications that connect and pull back geometries and see if things
> die there.  It is too bad you cannot connect to our test instance,
> since that takes your particular server configuration right out of
> the testing equation.
> Paul
> On 2-Dec-05, at 8:44 PM, Johan Wehtje wrote:
> > I have for some weeks now been trying to track down why i have not
> > been able to get Postgis working with Udig and have managed to
> > determine that the problem appears to lie with the Postgis JDBC
> > driver which I think is the same as the Jump Plugin.
> > I have not yet built the Latest version from CVS as as I have to
> > first install a JDK. I don't know how much work has been done since
> > the release of the Postgresql 7.4 compatible release, but with both
> > Udig and Jump dpending on this driver to use Postgis it would be
> > nice to see it updated to support 8.x Postgresql and 1.0.x Postgis
> > and a ready built Jar made available.
> > Cheers
> > Johan Wehtje
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051203/c6530abc/attachment.html>
