[postgis-users] libgeos.so.3
Stephen Davies sdc at sdc.com.au
Sun Dec 4 22:51:10 PST 2005
OOPS!  Yes. I did mean 2.1.4. Got a bit heavy handed with the 1 key;-)
I was rebuilding GEOS, GDAL and Mapserver to include both PostGIS and
ECW support. After a few failed attempts to get the ER Mapper libraries
to build, I resorted to building against some of the libraries in the
FW Toolkit. This is where libgeos.so.3 came into the picture.
It was also the way out as Frank's package also includes libgeos.so.3.
The bottom line is that I now have a version of Mapserver that supports
both PostGIS and ECW; which is fantastic. The only downer is that, as a
hybrid, it is less than fully portable.
Hopefully the stuff from ER Mapper will become easier to build.
Cheers,
Stephen
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>CC: Frank Warmerdam <warmerdam at pobox.com>
>You mean 2.1.4 probably (we never reached .14 ;).
>If GDAL requires libgeos.so.3 there's no release out yet.
>I thought, anyway, that GDAL was using the new C-API.
>If this is the case GEOS-2.2.0 should do.
>--strk;
>On Sat, Dec 03, 2005 at 11:16:17AM +1030, Stephen Davies wrote:
>Content-Description: signed data
>> G'day list.
>> Yesterday I compiled GEOS 2.1.14 and it built libgeos.so.2 rather
than
>> the expected libgeos.so.3.
>> What did I do wrong?
>> (I need libgeos.so.3 to build GDAL).
>> Will building the new 2.2 make a difference here?
>> Cheers and thanks,
>> Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s).  No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting                            Voice: 08-8177 1595
Adelaide, South Australia.                             Fax: 08-8177 0133
Computing & Network solutions.                       Mobile:0403 0405 83
Name: not available
Desc: signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051205/c9ba1ce0/attachment.pgp>
