[postgis-users] OIDs and AddGeometryColumn
Dylan Keon dbkeon.ml at gmail.com
Tue Dec 6 16:43:24 PST 2005
Hi all,
I upgraded a server to PostgreSQL 8.1.0 and PostGIS 1.0.5 (coming from
7.4.5/0.8.2 - ancient, I know :).  I can't do a SELECT
AddGeometryColumn, apparently because there are no OID columns in the
restored tables.  The default behavior in 8.1 is to not create OIDs.
  tsunami=# SELECT AddGeometryColumn('temp','geom',-1,'POINT',2);
  ERROR:  column reference "oid" is ambiguous
Do I have to force OID creation just so that I can use
AddGeometryColumn?  Or am I missing something?
Thanks much,
Dylan
Full output:
CONTEXT:  SQL statement "UPDATE geometry_columns SET f_table_schema =
n.nspname FROM pg_namespace n, pg_class c, pg_attribute a,
pg_constraint sridcheck, pg_constraint typecheck WHERE (
f_table_schema is NULL OR f_table_schema = '' OR f_table_schema NOT IN
( SELECT nspname::varchar FROM pg_namespace nn, pg_class cc,
pg_attribute aa WHERE cc.relnamespace = nn.oid AND cc.relname =
f_table_name::name AND aa.attrelid = cc.oid AND aa.attname =
f_geometry_column::name)) AND f_table_name::name = c.relname AND c.oid
= a.attrelid AND c.relnamespace = n.oid AND f_geometry_column::name =
a.attname AND sridcheck.conrelid = c.oid AND sridcheck.consrc LIKE
'(srid(% = %)' AND sridcheck.consrc ~ textcat(' = ', srid::text) AND
typecheck.conrelid = c.oid AND typecheck.consrc LIKE
'((geometrytype(%) = ''%''::text) OR (% IS NULL))' AND
typecheck.consrc ~ textcat(' = ''', type::text) AND NOT EXISTS (
SELECT oid FROM geometry_columns gc WHERE c.relname::varchar =
gc.f_table_name AND n.nspname::varchar = gc.f_table_schema AND
a.attname::varchar = gc.f_geometry_column )"
PL/pgSQL function "fix_geometry_columns" line 17 at SQL statement
SQL statement "SELECT  fix_geometry_columns()"
PL/pgSQL function "addgeometrycolumn" line 142 at select into variables
SQL statement "SELECT  AddGeometryColumn('','', $1 , $2 , $3 , $4 , $5 )"
PL/pgSQL function "addgeometrycolumn" line 4 at select into variables
tsunami=#
