[postgis-users] problem compiling postgis 1.0.5 and 1.0.6
Guillaume Sueur guillaume.sueur at geosignal.fr
Wed Dec 7 03:27:15 PST 2005
yes, that's what I did :
configure and make of postgresql 8.1
launching of the new postmaster
copy of postgis tree into the postgresql.8.1.0/contrib directory
modification of the makefile.config for geos and proj support
configure
make --> fails !
strk at refractions.net a écrit :
> On Wed, Dec 07, 2005 at 12:17:58PM +0100, Guillaume Sueur wrote:
>>Hi,
>>an old problem shows up again.
>>I've upgraded from postgresql 8.0 to 8.1 and it went ok, the postmaster
>>is running again.
>>But when I try to compile postgis 1.0.6 or 1.0.5 from the contrib
>>directory, I have the following message : usr/bin/ld: can't find -lpq
>>I checked these points :
>>	- libpq.so is under /usr/local/pgsql/lib
>>	- /usr/local/pgsql/lib is in /etc/ld.so.conf
>>	- ldconfig has been run after that.
>>and I still have the same problem.
>>Any idea ?
> The postgresql source must be configured and built.
> Postgis 1.0.x still uses data in pgsql source tree.
> --strk;
>  /"\    ASCII Ribbon Campaign
>  \ /    Respect for low technology.
>   X     Keep e-mail messages readable by any computer system.
>  / \    Keep it ASCII.
> postgis-users mailing list
Guillaume SUEUR
GEOSIGNAL - Groupe BVA
25bis Avenue Marcel Dassault
31505 TOULOUSE CEDEX 5
