[postgis-users] additional libraries for av_pgcon
Armin Burger armin.burger at gmx.net
Mon Dec 12 11:12:06 PST 2005
Robert,
thanks for the hint. I also had these files in the system search path so
they could be found by pgsql2shp and I did not get the errors. I will
add the dll's to the installation zip file and will put a new version on
the download dir.
Armin
Robert Burgholzer wrote:
> I ran into trouble installing av_pgcon on a new machine (ArcView 3.3,
> with latest version of av_pgcon ), and found that pgsql1shp.exe (windows
> based) required a few additional libraries in order to operate. This
> manifested itself in an error which read
> "could not create theme from defined parameters"
> In the av_pgcon window. The layer loaded fine after putting the
> following libs in the BIN32 directory:
> libeay32.dll
> libiconv-2.dll
> ssleay32.dll
> I can only assume that these libraries might be in my previous install
> as a result of using postgresql on the client machine, or some other
> open source tool.
> Robert W. Burgholzer
> Nonpoint Source Data Analyst
> University of Maryland, College Park
> Chesapeake Bay Program Office
> 410 Severn Avenue, Suite 305B
> Annapolis, MD, 21403
> Phone: (410) 267-5779
> rburghol at chesapeakebay.net <mailto:rburghol at chesapeakebay.net>
> http://www.chesapeakebay.net/
> postgis-users mailing list
