[postgis-users] Initial SRS and geometry columms table creation
Gregory S. Williamson gsw at globexplorer.com
Tue Dec 13 20:57:32 PST 2005
Ivan --
> I am just starting out with PostgreSQL and PostGIS.  It appears that it is
> necessary to create the SRS and geometry_columns tables before importing
> ESRI shapefile data.  Is this correct?
Yes -- this is done by the sql script (lwpostgis.sql in postGIS 1.x) that creates the function interfaces that postGIS uses.
>                                         One thing that seems odd though is
> that in order to create the geometry_columns table one would have to know
> what tables are going to be produced by importing GIS data into the database
> and the resulting name of the geometry_column.
The table is created when the postGIS functions are created, but it is not populated until later. Basically, you create a table, then add a geometry column to the table with AddGeometryColumn and the new reference gets added to the geometry_columns table itself.
> I am also wondering if it is necessary to create a spatial table first for
> each shapefile that one is adding to the database or if one may merely use
> the loader to create the feature table then modify it by adding a geometry
> column to it.
I think the shp2pgsql program can be told to create a new table:
USAGE: shp2pgsql [<options>] <shapefile name> <table name> <database>
OPTIONS:
  -s <srid>  Set the SRID field. If not specified it defaults to -1.
  (-d|a|c) These are mutually exclusive options:
      -d  Drops the table , then recreates it and populates
          it with current shape file data.
      -a  Appends shape file into current table, must be
          exactly the same table schema.
      -c  Creates a new table and populates it, this is the
          default if you do not specify any options.
  -D  Use postgresql dump format (defaults to sql insert
      statments.
  -k  Keep postgresql identifiers case.
> Lastly, I have a spatial reference system that is not defined in EPSG.  It
> is a system for the entire state of California in NAD83 defined thusly:
Not having done this myself I will let someone with more experience guide you. You would want to create the new SRID entry before loading data, or else load the data as SRID -1 and then create the new srid and run a postGIS function to recast it. Of the two I'd opt for the first.
HTH.
Greg Williamson
DBA
GlobeXplorer LLC
